Jagdtiger No.41 in Germany
Chang
Has liked: 16559 times
Been liked: 487 times
Re: Jagdtiger No.41 in Germany
Post by Chang »
A fantastic upgrade of the modified A-frame Gun traveling lock. I like it very much Sascha.
Christoffer Ahlfors
Has liked: 746 times
Been liked: 359 times
Post by Christoffer Ahlfors »
Beautiful job, Sasha!
I wish Per could have seen this - he would have approved! :D
Has liked: 161 times
Been liked: 830 times
I love your travel lock and other details. Fantastic!
Robert Tanzer
Has liked: 1121 times
Been liked: 990 times
Post by Robert Tanzer »
Great job you make. Hat of for you Sir.
Wher did you get that nice looking Bosch lamp?
Robert
David Brady
Has liked: 213 times
Been liked: 840 times
Post by David Brady »
Lovely looking welds
Chang
Post by Chang »
Hi Sascha,
How long will it take for the welding seam—— I reckon it was made by epoxy putty—— to dry? After that, does it shrink?
I have used one kind of the car body filler on other models, which took very long time to dry, and get shrank.
Car body filler.jpg (40.1 KiB) Viewed 12039 times
Thanks.
Lerh Chang
Has liked: 2282 times
Been liked: 7196 times
Nice work, that pigs head is huge! 8)
Björn Johansson
Has liked: 481 times
Been liked: 408 times
Post by Björn Johansson »
Fantastic details , :roll: :roll: :roll: perfection is amazing !
Kind regards from Björn
Gerhard Michel
Has liked: 3 times
Been liked: 687 times
Post by Gerhard Michel »
Hi Sascha,
50 mm recoil length IMHO will hardly fit a Jagdtiger, because the huge recoil was like a trademark for this gun. Is there really no way to achieve some more recoil? My JT (made by Bigtanks) allowed me to install even 150 mm recoil length which was the stop point for a very hot gun.
Gerhard
Excellent workmanship, worth all the effort, regards simon manning.
Gerhard Michel
Has liked: 3 times
Hi Sascha,
okay, with the light weight Bigtanks barrel made of glass fibre braid I had much less trouble to realize a long recoil way and a sufficient slide bearing. I only had to use a servo with an extended horn and a slide bar for the end of the barrel. But I think this solution might also be possible with an Armortek JT, if a 60 kg servo is used. E.g. my Armortek Jagdpanther has such a solution for its recoil, realized by a linear ball bearing.
JT Barrel in rearmost position:
Barrel in foremost position:
I had to use rather flat LiFePO4 cells to get the available space for the recoil when the barrel is in maximum elevation position.
Gerhard
Gerhard Michel
Has liked: 3 times
Hi Sascha,
a very interesting idea to use compressed air instead of electricity. :idea:
Gerhard
Gerhard Michel
Has liked: 3 times
Hi Sascha,
congratulations to your superb work!
Gerhard
Robert Tanzer
Beautiful work you do.
Follows this with great interest I want to do something with my recoil in my Tiger One.
Robert
Derek Attree
Has liked: 219 times
Been liked: 200 times
Post by Derek Attree »
Hi Sascha
Some nice engineering going on here very impressive.
Regards Derek
