Jagdtiger No.41 in Germany
- Chang
- Has liked: 16564 times
- Been liked: 487 times
Re: Jagdtiger No.41 in Germany
A fantastic upgrade of the modified A-frame Gun traveling lock. I like it very much Sascha.
- Has liked: 746 times
- Been liked: 359 times
Beautiful job, Sasha!
I wish Per could have seen this - he would have approved!
- Has liked: 161 times
- Been liked: 830 times
- Has liked: 1121 times
- Been liked: 990 times
Great job you make. Hat of for you Sir.
Wher did you get that nice looking Bosch lamp?
Robert
Robert
- Has liked: 215 times
- Been liked: 840 times
- Chang
Hi Sascha,
How long will it take for the welding seam—— I reckon it was made by epoxy putty—— to dry? After that, does it shrink?
I have used one kind of the car body filler on other models, which took very long time to dry, and get shrank.
Thanks.
Lerh Chang
Thanks.
Lerh Chang
Nice work, that pigs head is huge!
- Has liked: 481 times
- Been liked: 408 times
- Gerhard Michel
- Has liked: 3 times
- Been liked: 687 times
Hi Sascha,
50 mm recoil length IMHO will hardly fit a Jagdtiger, because the huge recoil was like a trademark for this gun. Is there really no way to achieve some more recoil? My JT (made by Bigtanks) allowed me to install even 150 mm recoil length which was the stop point for a very hot gun.
Gerhard
Gerhard
- Been liked: 1767 times
- Gerhard Michel
Hi Sascha,
okay, with the light weight Bigtanks barrel made of glass fibre braid I had much less trouble to realize a long recoil way and a sufficient slide bearing. I only had to use a servo with an extended horn and a slide bar for the end of the barrel. But I think this solution might also be possible with an Armortek JT, if a 60 kg servo is used. E.g. my Armortek Jagdpanther has such a solution for its recoil, realized by a linear ball bearing.
JT Barrel in rearmost position:
Barrel in foremost position:
I had to use rather flat LiFePO4 cells to get the available space for the recoil when the barrel is in maximum elevation position.
Gerhard
Gerhard
- Gerhard Michel
Hi Sascha,
a very interesting idea to use compressed air instead of electricity.
Gerhard
Gerhard
- Gerhard Michel
Hi Sascha,
congratulations to your superb work!
Gerhard
Gerhard
Beautiful work you do.
Follows this with great interest I want to do something with my recoil in my Tiger One.
Robert
Robert
- Has liked: 219 times
- Been liked: 200 times
Hi Sascha
Some nice engineering going on here very impressive.
Regards Derek
Regards Derek
