Page 3 of 5
Re: The Sonderanhanger 115 10 ton trailer.
Posted: Mon Jan 11, 2021 5:50 pm
by Phil Woollard
As it's quiet some more progress on the 115
Exploration20@outlook.com
Posted: Mon Jan 11, 2021 6:12 pm
by simon_manning
Looking very good Phil, an impressive vehicle, it's Taking shape nicely, regards simon.
Posted: Mon Jan 11, 2021 7:25 pm
by Phil Woollard
Thanks Simon I just need your half track to pull it!
Posted: Mon Jan 11, 2021 7:36 pm
by Graham Ord
Hi Phil
Can you please tell me what you are using for the center front to back planks?
I am planning to make a model of a Ransome and Marles Thresher (circa 1926) which is clad in planks.
Thank you
Graham
Posted: Mon Jan 11, 2021 7:51 pm
by Phil Woollard
Hi graham, it's 6mm hardwood marine ply which gives great strength and stability. Try to buy marine ply as the glue for obvious reasons is not affected by moisture.
Don't be tempted to use individual hardwood planks as you will have a hell of a job keeping it all in place.
I'm old enough to have worked on a farm that used the ransoms thresher machine although I was very young at the time
Posted: Mon Jan 11, 2021 8:45 pm
by Christoffer Ahlfors
Phil Woollard wrote: ↑Mon Jan 11, 2021 7:25 pm
What a dream, to see the two together!
Posted: Mon Jan 11, 2021 8:53 pm
by florian rudolf
It's realy a great build Phil,
would like to see it real...
Maybe on Militracks?
Posted: Mon Jan 11, 2021 9:54 pm
by Graham Ord
Thanks for the info.
Graham
Posted: Thu Jan 14, 2021 5:23 pm
by Phil Woollard
Lots done with the "special trailer 115"
Posted: Fri Jan 15, 2021 2:40 pm
by Kevin Hunter
Phil, this is an outstanding build and it’s a real treat to watch the trailer developing.
Keep it up
Kevin
Posted: Fri Jan 15, 2021 8:06 pm
by Graham Ord
Hi Phil
Ref your planking, I have studied the joints and they look like they are burnt in. How did you do that?
They look very realistic.
Graham
Posted: Sat Jan 16, 2021 7:55 am
by Phil Woollard
Graham all I'm going to say is, mark out the planks and the simulated fixings being as accurate as you can, any discrepancy will look pants and you will lose the illusion. Use a stylus following the grain where possible, fill the depression with your chosen medium and clean up.
Phil.
Posted: Sat Jan 16, 2021 9:12 am
by Graham Ord
You are a master craftsman and as one model engineer to another I take my hat off to you.
Graham
Posted: Sat Jan 16, 2021 9:23 am
by Phil Woollard
Cheers Graham you are a gent.
Posted: Sun Jan 17, 2021 10:45 am
by Ray Brown
G'day Phil,
I follow all your great builds. You get through them so quick. Any thoughts to do àn elefant?
Ray
