Page 3 of 8
Re: Jagdpanther no 13
Posted: Tue Apr 13, 2021 1:20 pm
by simon_manning
Keep at it Dave, it's a Lifetime of rubbing down Metal, Nice Part's, regards simon.
Posted: Sun Jun 13, 2021 6:49 pm
by David Brady
Thanks Simon - some more progress, flame cuts and fake welds in progress.
Posted: Sat Jun 26, 2021 1:33 pm
by David Brady
More progress, front suspension and motors installed.
Posted: Sat Jun 26, 2021 4:41 pm
by Robert Tanzer
David you are a lucky man.
Have a Jagdpanther, I am so jealous. :D
You make some nice work with it, hat of for you Sir.
Greetings from Sweden
Robert
Posted: Sat Jun 26, 2021 6:52 pm
by David Brady
Thanks Robert, comments appreciated.
Posted: Sun Jun 27, 2021 7:54 pm
by David Brady
Stripped the elevation and lateral movement mechanism back to components, cleaned and etch primed then final paint applied
Posted: Sun Jun 27, 2021 7:59 pm
by Robert E Morey
Awesome work David! Better than new!
B
Posted: Sun Jun 27, 2021 8:33 pm
by Christoffer Ahlfors
David, that was just one sentence, but I am sure it was a lot of work! :shock:
The result is truly beautiful!
Posted: Sun Jun 27, 2021 8:44 pm
by Robert Tanzer
Just eye candy, these pic's.
Robert
Posted: Mon Jun 28, 2021 12:36 pm
by simon_manning
That looks better Dave, These old girls come back to life with a little TLC, Regards simon.
Posted: Tue Jun 29, 2021 11:05 pm
by David Brady
Thanks all, trying to do a little each day
Posted: Sun Jul 04, 2021 9:43 pm
by David Brady
Hi,
Gear cases attached and gear loctited to bearings, this should prevent the gear contacting with the hull side.
Gear case armor pinned and loctited.
Mantlet secured into position, adjustment required to centre the large securing cone bolts on bottom row.
Lifting lug added
Posted: Mon Jul 12, 2021 3:36 pm
by David Brady
Hi,
Anyone got any experiance with the perfect angle to set the jagdpanther suspension, my model has an angle range from 38 to around 50 already ground
I've had a panther in the past that was set to around 35 degree, this was to low as the tracks hit the underside of the pannier when going over small obstacles
Posted: Mon Jul 12, 2021 4:47 pm
Advice from Mark in 2007 :D
"It also seems that the Panthers tend to be rear end heavy. consideration should be given to setting the front four suspension arms to 35 degs and rear four to 40 degs to overcome this. Final trim can then be adjusted by moving the internal fittings, batteries etc, a little fore or aft."
Posted: Mon Jul 12, 2021 5:02 pm
by David Brady
Thanks Adrian, the model was sitting at what looked the right height when purchased so was going to leave as it was, now all bars are fitted looking at the up down up down angle I'm not so sure.
Front angle 45 to 50 first three
Middle 38 to 45
Rear 45 to 50 last two
