Page 3 of 16
Posted: Thu Sep 17, 2020 6:44 pm
That's a sketchy piece of work holding !!
Posted: Thu Sep 17, 2020 9:35 pm
by Vince Cutajar
Always nice to see the printed results. They turned out quite well.
Posted: Fri Sep 18, 2020 8:51 am
by Phil Woollard
Your not wrong Adrian, should use a steady really but just skimming off the soft solder seems ok. Vince I'm very pleased with the printed parts and if I ever come across the ali kit parts I can easily change them out.
Posted: Fri Sep 18, 2020 9:08 am
by Vince Cutajar
Or maybe a live center.
Posted: Fri Sep 18, 2020 9:20 am
by Phil Woollard
I'm always in to much of a rush!
Posted: Sat Sep 19, 2020 5:37 pm
by Phil Woollard
More progress, she's taking shape.
Posted: Tue Sep 22, 2020 5:14 pm
by Phil Woollard
Still working on the rear plate details.
Posted: Tue Sep 22, 2020 8:48 pm
by Christoffer Ahlfors
The lower one, but if you want the crank to be left in, you will have to make the modification to the plate to make it horizontal, or you risk that every bypassing rivetcounter will embarrass you.
You are on such a high level anyway, or are you going to shoot this one up?
by Vince Cutajar
I'm going for the hl230 motor so which crank hole position do I use?
Page 40 of the Modeler's guide to the Tiger Tank gives a hint. For the HL230 (as I understand it), the hole closest to the edge of the starter plate is used for the starter shaft.
Posted: Wed Sep 23, 2020 9:10 am
by Phil Woollard
Thanks guys, reading up on the subject, when the hl230 was produced the manual crank starter engine dog coupler was slightly offset to the right compared to the hl210, hence the two threaded crank positions on the starter plate. The plate could then be used with whatever engine the Tiger had installed. I may need to enlarge the access hole in the rear plate.
My plan when Hermes, the most useless carrier ever decide to deliver my parcel from Kees in NL is to fit the panther sounds card, my reason, I'm just not keen on the 131 recorded sound. I really don't think that the Tiger would have ever made that din, the aftermarket fan drive gearboxes certainly don't help. So I shall fit it record a video and we can all decide!
should be interesting.
Posted: Wed Sep 23, 2020 1:54 pm
by Phil Woollard
I think that's the starter plate and crank done
Posted: Wed Sep 23, 2020 2:39 pm
Nice work. Now you just need to motorise it so Hans acts like the bloke on Camberwick Green
Posted: Wed Sep 23, 2020 3:23 pm
by John Clarke
Not forgetting to nail his boots to the table first
Got to add, lovely engineering
Posted: Wed Sep 23, 2020 3:28 pm
by Vince Cutajar
My impression is that a step drill is used for sheet metal.
Will it work on the rear plate?
Posted: Wed Sep 23, 2020 4:18 pm
Should work if you attack it from both sides. Depends on the size of this step drill.
