Yves Stug III update
- Steen Vøler
- Has liked: 62 times
- Been liked: 498 times
- Been liked: 571 times
Re: Yves Stug III update
Hello,
Workt all day on the stug, a lot sanding to do, filling up the holes with milliput.
Work on the upper structure.
Drilling 8 holes in each vent side to glue the hex bolts in to fix the grills.
Best regards Yves
Best regards Yves
- Roy Beukeveld
- Has liked: 171 times
- Been liked: 118 times
Thanks Roy,
At the end of the day i will post some new pictures.
Best regards Yves
Best regards Yves
Hello,
More work on the hull today,
Made a little detail on the side grills, insert 8 hex bolts on each side,
Drill 2 holes and tap thread with M4 and put countersink bolts in to fix the gun mount,
And close the holes with Milliput.
Tomorrow is another day to work on the stug
There are a lot of welding to do on the stug
Best regards Yves
Best regards Yves
Hello,
Here a little update on the stug,
Drill and tap thread M3 in the front armorplate, for the extra bar of the tracklinks
Put some extra detail on the roof and later comes a telescoop in the opening.
Made also a extra detail on the smoke dischargers
Best regards Yves
Best regards Yves
- Steen Vøler
- Roy Beukeveld
Hi Yves, Nice... I think I might copy your idea here... an extra bar of track links can be a nice addition to the model as quit a lot of StuG's drove around with a provision like that.yves mouton wrote: ↑Fri Nov 06, 2020 11:38 am...Drill and tap thread M3 in the front armorplate, for the extra bar of the tracklinks...
The bar from what I have seen, often extended over to the sides and was welded on there, but the two holes you added here on the front can be used very well to simulate that type of construction too...
Kind regards,
Roy
Roy
Hello Roy,
Thanks for the compliments.
I know that normaly the trackholder is weld on the side (or screws )
There are maybe different thinks to put a tracklink bar on ( i like to use some of my own inspiration )
but one of the things is that i am gonna place the trackholder last on my build because if you
put the track bar on you cant get the tracklinks in because the conehead bolts are in the way,
so first i have to paint the stug before i can put the tracklinks behind the bar.
Best regards Yves
Best regards Yves
Hi,
Today i did some detail work and started with the welding.
Tomorrow i go do more weldings.
Regards Yves
Regards Yves
- Has liked: 293 times
- Been liked: 639 times
Tomorrow Florian than i work on the weldings again,
there is a lot of welding to do on the stug
Best regards Yves
Best regards Yves
Yes indeed. I know and buyed enough milliput allready.yves mouton wrote: ↑Sat Nov 07, 2020 6:42 pmTomorrow Florian than i work on the weldings again,
Best regards Yves
Is somebody using the StuG parts from armorpax? I found parts from the commander hatch quite nice. Are some other parts from armorpax usefull?
cheers
Florian
