Chieftain Prototype Build
Has liked: 2282 times
Been liked: 7196 times
Re: Chieftain Prototype Build
Wow indeed, I'm looking at the available space over the motors for those half engines (plural), or if I move the motors and gearboxes towards the middle of the hull I would then have a blank canvas, albeit the chain drives in the way, so much to think about 8)
Could I be cheeky and ask the boss to just place a rule into the engine bay and let us know the distance available between the deck and the motors please? :) It might seem trivial but it's something that I need really to discuss with the guy that is going to produce the model engine.
Looking at the photo I think I may be able to slip the vertically apposed L60 in between those electric motors, well a good percentage of it anyway. If at all possible I want the fan drives to be functional, with maybe the flywheel spinning also.
Online
Mark Heaps
Has liked: 270 times
Been liked: 327 times
Post by Mark Heaps »
Looking very nice but the back decks really need the T-Piece, and if it is to be realistic then the serial number ( VRN ) needs to be on the T-Piece as well as on the hull.
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Post by Richard Goodwin »
Mark Heaps wrote:
Sat Jun 22, 2019 5:05 pm
Mark,
Would the VRN be the Registration No or a Chassis No? Also, would it be raised or stamped in?
Been liked: 3713 times
Machining of the turret has started. First op has been to mill a flat surface and a recess for the turret ring to eventually fit.
Ruler is just there to give a size comparison .. that is not really how we measure :-)
You know that steel rule......would you mind just slipping into that beautiful engine bay perchance :roll: 8)
That thing is huge, for a second I thought that was a 6" steel rule!
Been liked: 1843 times
WOW :D
Richard Goodwin
If only Armortek made beer............ :twisted:
Hi Richard
Maybe they could! and you could get tank'ed :P :P :P
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Post by Kevin Hunter »
But what good is a 1/6 pint?? :D
We have made some good progress on the prototype over the last couple of days.
Turret has been machined as well as the front armour. Pretty pleased with how it has all turned out so far.
4. Bin Catches Armortek Chieftain.JPG (74.16 KiB) Viewed 3891 times
AND FINALLY .....
Chieftain vs. The Elefant
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Looking good,
Can you post a pic showing how long the Chieftain is compared to the Elefant
David Brady
Has liked: 216 times
Been liked: 840 times
Post by David Brady »
Looks amazing well done Armortek
WOW :D :D :D
A very impressive beast, The customers getting one should be very pleased, stunning model. regards simon.
andymusgrove
Has liked: 198 times
Been liked: 89 times
Post by andymusgrove »
Very pleased Simon 😁. She is looking fantastic.
Well done Armortek
