Page 3 of 6
Re: ELEFANTE
Posted: Sat Jan 26, 2019 4:43 am
by Alberto Barba
This is how the periscopes of the driver’s hatch comes on the kit...
Re: ELEFANTE
Posted: Sat Jan 26, 2019 4:49 am
by Alberto Barba
But with some milling work, scratching the periscopes and some aluminium pieces... was fixed
Re: ELEFANTE
Posted: Sat Jan 26, 2019 4:55 am
by Alberto Barba
And that’s it, driver’s hatch periscopes and cover ready
Re: ELEFANTE
Posted: Sat Jan 26, 2019 5:12 am
by Alberto Barba
Now the fixing of the front fenders supports
Re: ELEFANTE
Posted: Sat Jan 26, 2019 5:15 am
by Alberto Barba
Sorry again for the secuence of the photos...
Re: ELEFANTE
Posted: Sat Jan 26, 2019 5:23 am
by Alberto Barba
Reworked fender supports in position
Re: ELEFANTE
Posted: Sat Jan 26, 2019 5:27 am
by Alberto Barba
Corrected fender hinges, tree segments insten four...
Re: ELEFANTE
Posted: Mon Feb 04, 2019 10:59 pm
by Alberto Barba
Fender springs...
Re: ELEFANTE
Posted: Tue Feb 05, 2019 1:22 am
by Chang
Hola Alberto,
How nice to see the diamond pattern aluminium sheet and little front-fender springs were added in your Elefant.
I have done the addings too. For me they are the must details that can't be ignored, and I shall say that you have done it beautifully. :idea:
BTW, what are these and what are they for?
Lerh Chang
Re: ELEFANTE
Posted: Fri Feb 08, 2019 5:21 am
by Alberto Barba
Hello Chang !
Well thanks to you we have the dimond patern !... thanks a lot.
Ok the screws you see are the ones to hold the super structure to the main chassis, son I will explain what we do...
Re: ELEFANTE
Posted: Fri Feb 08, 2019 5:22 am
by Alberto Barba
They was cut... 8)
Re: ELEFANTE
Posted: Fri Feb 08, 2019 5:27 am
by Alberto Barba
Meanwhile, other detail finnished, inside of the muzle brake... in the second picture the muzle brake is empty
Re: ELEFANTE
Posted: Fri Feb 08, 2019 5:45 am
by Alberto Barba
The idea is to hide all the bolts that hold from the exterior all the plates, after that we try to use the ones that the Elefat has in real life, we change the internal metallic angles and switch with a aluminium ones thiker of course to tap it, so, unscrewing the bolts you see in the pictures is the only thing you need to remove the entire engine deck :wink:
Re: ELEFANTE
Posted: Wed Feb 13, 2019 1:55 am
by Alberto Barba
Now some adjusts to the barrel travel lock
Re: ELEFANTE
Posted: Wed Feb 13, 2019 1:59 am
by Alberto Barba
And again we hide the bolts that holds the travel lock
