First Quad's arrive with customers
Walter Mackinnon
Has liked: 8 times
Been liked: 4 times
Re: First Quad's arrive with customers
Post by Walter Mackinnon »
Hi all.
Just finished cleaning and etch primeing all the metal parts.
Not had any problems with assembly with the parts painted.
Regards Walter.
Phil Crowther
Been liked: 10 times
Post by Phil Crowther »
Chris, thanks for the tip. I'll give that a go and let you know how it goes.
On the up side, the gearbox fell together with their greatest of ease. But stone me it's a heavy lump when finished. I'm almost glad I couldn't afford the bergepanther!
Phil :)
Phil Crowther
Thanks to those who made helpful suggestions I have now solved the steering problem. It took a bit more fettling than I was comfortable with,as a plastic modeller, but the result was worth it.
Problem solved...... on with the build.
Now about this radio control malarkey...? :?
Phil Crowther
Can anyone out there tell me how I can fix the two Towing Latch Springs so that they don't launch themselves across the room at the first opportunity? :|
Has liked: 1481 times
Been liked: 1687 times
I've spent quite a while looking at walkarounds on the net and I've not seen any tow hitches with springs attached. They all appear to be as below:
Phil Crowther
Thanks Adrian. That's very useful
Been liked: 3699 times
Phil, Adrian
Yes, it is correct that the full size tow hitch has no springs. But if you run the model like that, the weight on the 25pdr will flip the limber off the tow hitch.
