Page 3 of 17
Posted: Fri Jul 24, 2009 7:12 pm
by Jeffrey Goff
Hi Simon, good to see you doing some work, the KT mods look great, and your Tiger 1 looks fantastic
regards
Jeff
Posted: Sat Jul 25, 2009 1:54 am
by Tim Bowman
Hi Simon,
What Jeff said!
Love the mesh covers on the intake and exhaust fan guards! Great job on the guards themselves as well. Keep the pictures coming please.
Posted: Sat Jul 25, 2009 10:33 am
by Kent Wiik
Hi Simon
Wow! That is some high quality builds you have there.
Love your attention to details - keep up the good work.
/Kent
Posted: Sat Jul 25, 2009 5:02 pm
by Robert E Morey
Simon,
Brilliant work on the mesh gaurds for the fans and grilles. They look awesome. The cast numbers look great. Nice work all around.
Still don't know how you can work on several models at the same time!
Posted: Fri Aug 07, 2009 7:11 pm
by simon_manning
Posted: Sat Aug 08, 2009 4:03 pm
by simon_manning
Posted: Sat Aug 08, 2009 5:37 pm
by Tim Bowman
Excellent Simon
Love the rear deck photos!
Posted: Sat Aug 08, 2009 10:57 pm
by Dale jordan
Hi Simon . Your KT is looking amazing!!! . Are you going to fill the bolts holes and do the welds soon ?? otherwise it will be hard to do it when all the detail in on ....Dale
KT build
Posted: Mon Aug 10, 2009 8:41 am
by Martin Taylor
Hi Simon....great pics! Can you tell me what wire gauge and mesh size you have used for the grille covers?
Martin
Posted: Mon Aug 10, 2009 1:25 pm
by simon_manning
hi martin, they are the standard ones supplied with the king tiger kit,mark at armortek will know, time consuming to fit,but the end result looks o.k.
hope this helps,simon manning.
Posted: Mon Aug 10, 2009 1:33 pm
by Chang
Hi Simon,
The aluminum U-shape frame for rear deck is a brilliant idea!
Only concerned is the deck supports LH(CK0115) & RH(CK0115_M). Are they still being used?
Thanks for sharing this.
Lerh Chang
mesh
Posted: Mon Aug 10, 2009 2:02 pm
by Martin Taylor
Thanks Simon, I'm only opening the packs as I get to that stage and had missed the reference to mesh in the manual as it is in the "details" pack rather than the grilles. Your way to achieve a single deck structure looks very good indeed....thank you for sharing it!
Martin
Posted: Mon Aug 10, 2009 4:46 pm
by simon_manning
hello chang, i left the deck supports out,using the u-channel as i did the fit is just right,i will use the existing holes behind the turret to secure the deck when being run,hope this helps.
Posted: Mon Aug 10, 2009 11:23 pm
by peter karlsson
hi simon!!!
just want to say fantastic work on your KT!!!
regards peter,peppe.
Posted: Tue Aug 11, 2009 10:14 am
by Chang
simon_manning wrote:hello chang, i left the deck supports out,using the u-channel as i did the fit is just right,i will use the existing holes behind the turret to secure the deck when being run,hope this helps.
Thanks Simon for the advice. I do learn this from you!
Happy building!
Lerh Chang
