Page 19 of 47
ROADWHEELS: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Posted: Sat Oct 27, 2018 6:57 am
by Brian Ostlind
Wheels not perfect but good enough
Posted: Sat Oct 27, 2018 7:00 am
by Vince Cutajar
Can't wait to see your hull rolling.
Posted: Sat Oct 27, 2018 7:48 am
by Brian Ostlind
Night night...
Posted: Sat Oct 27, 2018 9:18 am
by Phil Woollard
You could offer a mobile painting service with that set up ! 8) All I have is a window :lol:
Tracks: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Posted: Sat Oct 27, 2018 2:36 pm
by Brian Ostlind
Posted: Sat Oct 27, 2018 3:02 pm
by Brian Ostlind
Filter: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Posted: Sat Oct 27, 2018 6:00 pm
by Brian Ostlind
Posted: Sat Oct 27, 2018 7:32 pm
by Phil Woollard
Brian you are so organised! Did you like the photo of the Famo struggling with the Tiger 1 I posted?
Posted: Sat Oct 27, 2018 7:46 pm
by Brian Ostlind
I love it, it is encouraging for me as a model builder to know that the historical accuracy is not compromised by towing a 1/6 tank with only one FAMO instead of the normal three.
Posted: Sat Oct 27, 2018 9:25 pm
by Phil Woollard
My thoughts entirely, don't lose sleep over a river out of place! Sleep tight regards Phil.
Posted: Sun Oct 28, 2018 2:39 am
by Brian Ostlind
Wash wiped;
Tensioner: Brian's 2017 NO. 10 LATE TIGER 1 BUILD
Posted: Sun Oct 28, 2018 5:35 pm
by Brian Ostlind
Morning coffee and Armortek...I am heading to a Halloween themed farm for my son but hope to get all this put together when I get back. It’s been a long time coming!
Posted: Sun Oct 28, 2018 6:16 pm
by Brian Ostlind
I slipped these on quickly. What a great milestone! I’ll do the other side when we get back from the farm.
The sprockets get fixed at 16.5mm spacing from the hull side, is that correct?
Thank you in advance.
Brian
Posted: Sun Oct 28, 2018 7:12 pm
by Phil Woollard
To line it all up , install the tracks and leave the sprocket fixing just a tad loose, all the track horns should line up in the middle of the road wheel corresponding slots, gently pull the tracks around without the key in place . Eye it all up and when your happy install the key and tighten the sprocket tapper bush, then the counter sink screw and washer. The distance of the sprocket from the hull depends on how tight the suspension arms are against the hull bushes. Theres not a lot in it but get it correct and it will run like a dream! Hope this helps regards Phil.
Posted: Sun Oct 28, 2018 7:16 pm
by Brian Ostlind
Ok that all sounds pretty straightforward. I don’t know what csk screw and washer are you talking about?
