Page 15 of 18
Re: Florians FAMO build
Posted: Sun Jun 07, 2020 9:15 pm
by florian rudolf
Did some paintwork today.
It looks diffrent to other tank paints, but its frm al real Famo. With some weathering I think its looking good
Posted: Sun Jun 07, 2020 9:17 pm
by florian rudolf
Posted: Mon Jun 08, 2020 8:58 am
by Simon Peck
I like it. One of the best executed schemes I’ve seen.
Posted: Mon Jun 08, 2020 10:40 am
by florian rudolf
Thank you Simon,
I did'nt realy know if it looks good or not. It's verry special, but verry rare indeed.
Posted: Mon Jun 08, 2020 2:18 pm
by Marco Peter
I have to get used to it, weathering will really make it shine. But what I really like is how well you replicated it, skills!
Posted: Mon Jun 08, 2020 8:00 pm
by bryanrmassie
Oh my god Florian, I had the shock of my life when I seen this, it looked like Chinese graffiti !!!, HOWEVER - I think if you blend it in a bit it could be a really good look, sorry don't mean to offend but its better to be honest
Posted: Tue Jun 09, 2020 7:32 am
by florian rudolf
Good morning Adrian,
i thought the same when i was done.
Well, the first camouflage is not finished. weathering follows soon.
Lets have a look how its shows if finish.
Posted: Thu Jun 11, 2020 4:56 am
by Chang
Good'y Florian,
Far behind your building progress, I read this thread almost everyday for good ideas. Today I just need to ask for your opinion.
On your 28 Jan 2019 photo, the
linear actuator (CP0314) for steering shown a longer white rod (see the red arrows) :
- FAMO-167.jpg (81.67 KiB) Viewed 6113 times
When I try do the same thing, found the white area shown on my
linear actuator is very short. So short that it can't link with the steering arm.
- FAMO-168-2.jpg (66.13 KiB) Viewed 6113 times
Did I do it wrongly, or missing something? I have tried to pull the white rod outward, but just failed.
Do I need to do so by bench testing, ie, by connecting the battery, and connect R/C Tx, Rx, and the Motion Module? If no, what else should I do?
With regards,
Lerh Chang
Posted: Thu Jun 11, 2020 8:24 am
by Heiko Sattler
Posted: Thu Jun 11, 2020 8:38 am
by Armortek
Chang wrote: ↑Thu Jun 11, 2020 4:56 am
The actuator in your picture is completely retracted - this would be its position when the wheels are turning right. If you connect it to power it should centre (extend to its mid point).
Do not force the white rod by hand - this will damage the actuator.
Kian
Posted: Fri Jun 12, 2020 10:16 am
by florian rudolf
Danke für dein Lob Heiko. Das von dir, ehrt mich.
Kian is on the right way. Don`t try to pull or turn on the liear servo.
You have to connect the servo wiht the steering from the axle. Maybe the Wheel is not strait in front. - If this, you have to adjust it on your controler.
Posted: Fri Jun 12, 2020 10:47 am
by Heiko Sattler
Dein Famo würde gut an meine 88 Flak passen
Posted: Fri Jun 12, 2020 10:54 am
by florian rudolf
Definitiv
Wenn du nach Overlooon kommst kannst du sie ja mitbringen.
Alternativ habe ich ja noch meine PAK43/41
Mit deiner 88 is das Gespann dann ja locker 4m oder?
Mit meiner PAK komm ich auf Gespannlänge von gut 3m
Posted: Fri Jun 12, 2020 10:56 am
by florian rudolf
Just now I working on the Famo seats. I like the style from Phil's Famo seats. - Thats my reference
Posted: Sun Jul 19, 2020 6:01 pm
by florian rudolf
I start weathering my Famo, because I am waiting for some stuff for my seats...
