Page 12 of 18
Re: Mick's Panther A
Posted: Mon Jan 15, 2018 6:24 pm
by michael hilton
Lovely morning, after the heavy rain, it's also quite mild.....so, with rattle cans at the ready, here we go. The garage doors are flung open, there is a useful light wind blowing from front to rear. I call it my paint extractor fan....patented, of course.... Following a light rubdown with fine wet and dry, the turret, rear and front decks are removed to garage spray booth, aka Armortek box, and over sprayed with Army Paint Industrial, WH. Dunkel Gelb RAL 7028...Once dry the parts are relocated onto the hull...and in my usual way, I reconnected the electrics and ran a test. I have an inkling that I may be paranoid in this regard, nevertheless it has to be done....Mick
Posted: Mon Jan 15, 2018 6:59 pm
by Phil Woollard
She is looking so good Mick, now how about some weathering to bring her to life when all the dunk is applied ?
Posted: Tue Jan 23, 2018 6:11 pm
by michael hilton
Found time to spray the Dunkel Gelb, a certain amount of careful planning required here, as my good lady does not do 'smelly paint' . As before, the garage is 'out of bounds', far to cold, so rattle can at the slope, window wide open, go for it. So far so good....Mick
Posted: Wed Jan 24, 2018 1:17 am
by Robert E Morey
Mick
Your Panther is looking good. This is the process I enjoy most - the final painting. Getting close!
Posted: Fri Jan 26, 2018 4:47 pm
by michael hilton
Thank you Bob, I think the painting will be challenging to say the least. A little time and forethought should reap it's own rewards. As previously said, I am going for late 1944 Linear Splinter camouflage, that's a challenge in itself. I have two or three photographs to which I will refer. Then, on the advice of the 'masters of weathering'......who knows....Mick.
Posted: Sun Jan 28, 2018 12:03 pm
by michael hilton
Masking up takes some doing , but enjoyable.....
Posted: Sun Jan 28, 2018 12:12 pm
by Phil Woollard
She's looking good Mick, that's an unusual camouflage scheme but I like it, regards Phil.
Posted: Sun Jan 28, 2018 7:30 pm
by michael hilton
Hello Phil, thank you. I am enjoying your Quad/25PDR/Limber build by the way. I thought the 'splinter' camo would be different. Paint and weathering are not a strong point although I appreciate the excellent examples on the Forum. It is tricky masking around the many fittings to get the lines straight. I will use the Flecktarn Braun I have, in between the yellow and green, and then if all is well, a light dusting of mud.....Mick
Posted: Wed Jan 31, 2018 11:16 am
by michael hilton
I need to slow down....or someone will wake up and smell the paint
Posted: Wed Jan 31, 2018 11:37 pm
by simon_manning
looks very effective mick, good choice of camo, these angular patterns look good, regards simon manning.
Posted: Thu Feb 01, 2018 7:23 am
by Stephen White
Great stuff, Mick, be proud. Looks magnificent. Now, a filter to blend the colours and tone them down, some rendering to bring out the detail and ........ your light dusting of mud and hours more fun. If you’re not in a rush to complete, weathering is entertaining and if you use oils, no smell to raise complaints from the management. Thanks for sharing your fine build with us. Stephen
Posted: Thu Feb 01, 2018 5:03 pm
by michael hilton
Thank you for your useful comments Stephen and Simon, it is an enjoyable experience when you reach this stage in the build so I want to give it my best shot. I am using STUK professional precision masking tape...to prevent paint bleed....one or two very small areas need touching up, otherwise the tape works well....Mick
Posted: Thu Feb 01, 2018 5:17 pm
by Phil Woollard
That's a very nice build indeed, now you have to make it look mucky
...Phil.
Posted: Mon Feb 05, 2018 9:39 am
by michael hilton
Thank you Phil, I have delved deeply into the dark art of weathering....my brain is scrambled....however, I will be having a go. The Knowledge Base and the many videos on uTube have been most helpful. I have researched the many 'washes' used and formed a plan....of sorts. Work in small areas and a little goes a long way. Any road up, it's all an adventure...I will post as I go...mistakes and all. best wishes, Mick.
Posted: Wed Feb 07, 2018 1:15 pm
by michael hilton
Now me hearties, here we go......and I do realize that my 'weathering' efforts my not be to everyone's taste.
The camouflage pattern late 1944/5 linear splinter looked quite stark, so I started with a light wet and dry sanding over the whole hull to both remove the masking tape lines and tone down the colours. I understand that I now need to brush coat a 'fixer' over the hull. What diluted colour 'fixer' should I use to balance the camouflage colours ?
The next process is an overall diluted ' wash', but again what colour ? ....Mick
