My Stug conversion
Derek Attree
Has liked: 218 times
Been liked: 180 times
Post by Derek Attree »
So Guys
The elevation unit is bolted to the back of the gun.
I had to replace the mounting bracket and make a spacer block to
get things to fit the back of my gun mount.
I also machined 3 mm from the side of the rebate in the elevation arm to get things to line up.
I had to make an adapter plate to mount the elevation motor again to get things to fit my set up on the STUG,
The next problem was to get the turn gear and mounting to clear the elevation motor and also to fit in the space I have in the fighting compartment.
I will show how I did this in another post,
Derek :D
Has liked: 1384 times
Been liked: 1580 times
Derek, that's such a neat piece of engineering :D
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Derek,
As said a very nice piece of work. I don't suppose it applies to a Stug but the only minor nuisance I have found with my Tiger and Sherman is that the elevation motor hangs below the turret ring making it difficult to put the removed turret on the ground. If I were to re-build one of my tanks I would consider ways to mount the motor differently.
Allan Richards
Derek Attree
hi guys
Thanks Adrian :D It has taken a lot of working out.
I would also like to thank Stephen White for his information re the viewing port.
I will post a some more pictures of the work on the turn gear in the morning.
Derek Attree
Hi Allen
Yes the motor hanging down was an issue on the Panther but in the Stug
like the JP the the fighting compartment is fixed.
I will have the roof and the rear deck removable only.
Has liked: 126 times
Been liked: 758 times
First class work Derek, great solution. Does the Stug gun move side to side? How will you accomplish this motion?
Your details and machine work are superb. Keep us posted - always love seeing progress on this project.
Derek Attree
Hi Bob
Thanks yes the gun will move side to side I decided to section the turret
ring gear in the end and make a frame to fit round the pivot frame.
See pictures....In next post later tonight I hope.
Hi Derek
As always, a joy to watch your project as it unfolds. First class work.
Derek Attree
Hi Guys
Here are the photos of the turn gear work I have been doing for the gun.
Machining the mount for the turn gear
The turn gear cut from the turret turn gear
This shows the mock up frame that shows the size of the base plate of the fighting compartment to see clearance.
More to follow
Derek Attree
Hi Guys
Some more Pictures.
Not A lot of space to the back of the frame.
How I want to mount the turn motor I can use the supplied motor mount but I will need some mods to get it to fit.
Motor could go under the frame
I have doubled up the gear wheel to make it thicker.
I have made a brass pivot bearing for the gun and I have a PTFE washer
of about 60 mm dia that goes between the the base of the gun and the fighting compartment frame.
I Have modified turn motor mount so it fits my model.
And last the teeth.
I will fit it over the weekend. :D :D :D
Sven Strobbe
Been liked: 11 times
Post by Sven Strobbe »
Realy nice job.
Amazing what you can do if you have the equipment.
From the mind to the machine...
:wink:
Sven
It's a beautiful day to go out in my King Tiger
Derek,
I was thinking you could use a large servo for the side to side, but you've got it nailed with your soln. Motor mounted down looks perfect. Beautiful.
Derek Attree
Hi Bob
The motor has to go under the plate as it hits the roof if standing upright.
This is the problem of doing the work at a different location to the model,
It is an easy fix though.
I have one or to other clearance issues with the elevation hight and the roof that will need slight modification.
Nothing major though.
Derek Attree
Hi guys
I have made the changes to the elevation arm to give the clearance on the roof.
I will post pictures of the system in place tomorrow.
I have also been working to fill the 2 hatch holes in the side of
the hull as the Stug did not have those hatches.
I will then get it together for the show next weekend in London.
Derek Attree
Hi Guys
More pictures as promised
The gun and rotation unit in place.
First the PTFE washer.
The next 2 show the metal removed from arm to clear roof
All fitted
Motors
Last the gun back in place.
More to follow of the other bits I have been doing.
