88 parts
Forum for discussion relating to the 88mm Flak36
Has liked: 2282 times
Been liked: 7196 times
Re: 88 parts
Just the mid bracket to make for the barrel cleaning rods and then we are onto the hand brake mechanism, which looks a bit complicated.
The keen eyed will notice the double bend in the brakemans seat post, it looks so much better now.
Even the webbing strap on the mop end
Martin Usher
Has liked: 26 times
Been liked: 62 times
Re: 88 parts
Post by Martin Usher »
Great looking 88 Phil, always enjoy your builds.
looking forward to getting one myself.
how is the back nowadays?
Martin.
Re: 88 parts
Hi Martin, I'm looking forward to all the 88 builds it's a great model. My back, how long have you got? I was in hospital 3 weeks ago with multiple lower lumbar prolapse, I have surgery coming up, it's just a case of morphine and being very careful for now.
Do you have a half track to pull it, I guess the sdkfz 7 will be next on the new kit list.
Regards Phil
Martin Usher
Has liked: 26 times
Re: 88 parts
Hi Phil, sorry to hear of your continuing back issues, I'm sure bending over the workbench does not help matters much, you go easy there big guy.
love the 88, looking at all the builds posted and shake my head at the quality, I can only match in enthusiasm but strive for my best in build.
At present I'm building the Leopard and loving this kit.
deposit on the 88 & SDKFZ7 ,flying home in November for family and friends, settle the remainder then, hoping to meet the very helpful team at Armortek.
It may sound daft but i find sitting building these kits to be the most therapeutic feeling ever, an escape from everyday headaches and such..
keep as well as you can do Phil.
regards,
Martin.
Re: 88 parts
Martin I agree these builds are our escape from reality for sure.
Just a few parts made this afternoon.
Brakemans foot pegs, I will need four of these in total. Made from steel but soft soldered.
Rope coiled and rope bracket made and fitted
You will have to zoom in on the intermediate rod bracket to be able to see it in all its glory, a tricky little devil for sure but done now. The brakemans foot pegs live here.
Re: 88 parts
Foot rests all done and a few other jobs to, then I really am onto the hand brake mechanism, those that have the new 88 release will have lots of extra detail included, looking at the Armortek cad rendering you will get the hand brake mechanism.
Soft solder is plenty strong enough for these foot rests.
All done here , so I can now move onto the hand brake mechanism
Foot steps added to both boggies. Rear reflectors but which end is the rear?
Foot rests bolted in place.
You would not believe the hours that have gone into those foot rests
Cable drums now have the stowage straps with the cable end sockets neatly stowed
Chocks x4 with holders
Re: 88 parts
Plodding on through the detail.
The brake assembly front spring mounts
The air brake system couplers will be a nice addition, thanks to Steve Lewington for those parts
and coupled together
I may use that brass piece from a Tiger 1 commanders hatch ( I have a pair) to mount the rear brake mechanism
A quick test fit before I go any further
This piece of solid aluminium square bar with be milled out to form the skinnyer longer version of the draw bar.I just couldn't find an Armortek draw bar anywhere.
I can see it finished
A useful amount of tiny parts kept handy
It would be nice to have this functional
Re: 88 parts
The hand brake mechanism is taking shape.
I think it will work, well it will swivel as you pull and release the hand brake.
I think you get the idea
It takes ages to make these small parts
Those "C" shape parts are Panther hatch brackets
Milling the old Tiger 1 commanders hatch hinge
Re: 88 parts
A little done, well quite a lot really, it's just very small work.
Slotting the cable end swivels, that's an 3 mm long series end mill
Tiny right angle brackets
Two assemblies means double everything
The cable end swivels take a bit of work on the mill and the lathe, I run a hack saw down first to make its easier for the end mill cutter
The brake cables go off to the brake drums, they are to long right now.
I may make my own springs as I am not 100% happy with these, let's see what they look like with a few thou of paint first
Re: 88 parts
The hand brake shaft is coming on for the rear boggie.
This Tiger 1 fitting is not far off what I need to mount the link arm
Milling the round bar into square bar
Silver soldering the swivels
Delicate work sometimes needs some hand fitting
The radius bent and the slot milled out to accept the swivel
The link arm fitted and it functions, I'm quite looking forward to starting on the hand brake lever and the ratchet.
Anyone had their dro just stop working? It's had little use and is only two years old!
Last edited by Phil Woollard on Sat Sep 28, 2024 7:12 pm, edited 2 times in total.
Derek Attree
Has liked: 219 times
Been liked: 200 times
Re: 88 parts
Post by Derek Attree »
Hi Phil
Did you leave it plugged in and switched on as per the instructions ? otherwise the internal battery dies so you might need a new internal battery I have the wm16 mill with the same readout.
Hope this helps
Regards Derek
Re: 88 parts
That sounds like the problem Derek, an "M" was visible on the display and then it went blank, is the battery readily available?
Derek Attree
Re: 88 parts
Hi Phil
I don't know talk to warco they are helpful
Regards Derek
Re: 88 parts
There's still a few smaller jobs before I can fit the handbrake lever
The flying air hose mount
I've just poked the handbrake cables in these existing holes for now, really they need a bracket right next to the brake drums
Same with the front
Same with the front
The cables neatly routed
One of the inboard air hose connections, there's another at the forward boggie, another joint would then link the cruciform at both ends, so around 8 connectors in total
Re: 88 parts
That handbrake.
Shafts
Shafts
Silver soldered to the pivot bushes
Checking the height, I have no dimensions
The roughed out ratchet
2 mm pitch between the teeth
He's pointing at the shaft, it still needs the handle to be at the correct height
The release post has rivited guides, the tricky bit will be the release trigger pivot points as it must be functional.
Nearly done, the handle to turn, the release trigger, trim down the shaft, add a return spring, clean up and paint.
Last edited by Phil Woollard on Wed Oct 02, 2024 5:51 pm, edited 2 times in total.
