Jagdpanther no 13
David Brady
Has liked: 206 times
Been liked: 825 times
Re: Jagdpanther no 13
Post by David Brady »
Hi,
Some more progress.
Floor painted
Floor painted
Cleaning parts - glad this horrible job is over
Ready for a final sanding 60 grit
David Brady
Hi,
Some more progress
Primed and inside painted landrover ivory
Steve Winstone bumpstops and torsion bar covers fitted
Covers have been positioned to cover large counter sunk fastener - positions are not strictly by the book, orientation and Qty per side is correct
To many parts all over the place  time to get a few back together
That's more like it
That's more like it
Checking the fit
Checking the fit
Handy book
Handy book
These steel tracks have done some miles - China to the UK  then I sent them to Germany  - then back to<br /> the UK when I brought them back off Martin  - tracks will be used for static purpose on one of my panther variants
Should go a nice colour like my king tiger steel tracks
Mark Lawson Roof vent added
Been liked: 1747 times
Nice Extra's and looking good Dave, These were a great model and interesting to build, regards simon.
David Brady
Thanks Simon been looking at yours and Martin's Jagdpanther builds to get some ideas
David Brady
Hi,
Nice comparison -
David Brady
Hi,
A little more progress
Filled some combat damage
Filled a few holes
Filled a few holes
Mark Lawson hinges fitted - really nice!
David Brady
A few pictures of my sprockets being modified- only one side of the panther sprocket is removable - As I don't have a lathe or the skill to do this I sent them to Steve Winstone - many thanks Steve your help is most appreciated.
Sprocket after 12 years of running- this will be machined off
Picture with new steel ring attached - <br />Steve was only 80% happy as the sprockets would not run true  - looks 100%   - a true master
Chang
Has liked: 16466 times
Been liked: 485 times
Post by Chang »
David Brady wrote:
Sun Dec 20, 2020 10:09 pm
1-6 Jagdpanther.jpg (100.18 KiB) Viewed 7689 times
Hi David,
Are these two smaller hooks on the engine hatch the genuine Armortek's parts? If yes, what is the part code?
Happy building!
Lerh Chang
David Brady
Hi,
I will check and report tomorrow Chang
Picked up some good quality Secondhand G clamps today - as I never seem to have a large enough clamp.
David Brady
Hi,
Rear deck part numbers
Some more filler  - weld will be added
David Brady
Hi,
Spent some time over the weekend assembling my sprockets, 128 fasteners later and £100 less in my bank job was done.
Christoffer Ahlfors
Has liked: 745 times
Been liked: 359 times
Post by Christoffer Ahlfors »
Beautiful sprockets! :D
Is there a specific reason for making the entire outer part in one piece, rather than a ring and hub as on the inside?
David Brady
Hi,
Martin Hofmann would be best positioned to answer why not but I suspect it's down to less machining cost and no real benefit in a two piece design as steel rings will not need changing.
Martin Hofmann
Has liked: 151 times
Been liked: 1969 times
Post by Martin Hofmann »
Hi Chris,
Hi David,
David you are absolutly right, that's are the reasons why i don't made 2 parts. Only the recess between the teeth and the castellated nuts are simulating that this will be 2 parts - but not really.
This will be a very good looking Jagdpanther. Keep up the good work, very interesting to follow.
Regards Martin
David Brady
Hi
Been busy cleaning Steve Winstone rear Panther bins over the weekend as the inside was a little rusty.
After rust treatment and cleaning
A great improvement - should of taken a before and after picture
Should last another 11 years now, these bins add the extra Wow factor and are a must have - now all I need is another two sets.
Sent the mud guards back to the main dealer for some specialist work - thanks Steve amazing!
My new Steve Winstone Exhaust- these should make the tank go faster!
Rounded off and flattened 7ba hex fasteners used to attach side rail
