Help needed
- Has liked: 270 times
- Been liked: 327 times
Re: Help needed
You have broken the bond so the residual loctite is now just friction.
Up to you whether you want to do it now or later on when the parts may be a bit harder to get at.
- Has liked: 130 times
- Been liked: 137 times
- Has liked: 1566 times
- Been liked: 836 times
Re: Help needed
I'm about to build the drive sprockets on my early Tiger 1( 2015 version ). After examining the diagram on page 15 and test fitting parts I have a query with regards the hub cap part number CE2306 and bolts CP0153. I can't understand how this hubcap is fixed to the actual wheel. The 5 bolts on the outer edge barely protrude through to the other side of the cap, and the middle one doesn't at all. However, there are no corresponding holes in the wheel to screw them into anyway.
In addition what lubrication do people use for the drive gear.
- Has liked: 745 times
- Been liked: 359 times
Re: Help needed
The center bolt should be long enough to go into the threaded hole in the drive shaft.
We are advised to leave the gears dry, or use a dry lubricant, but there are other opinions out there.
Re: Help needed
I'll have a check with the centre bolt. What happens with the others?Christoffer Ahlfors wrote: ↑Thu Feb 18, 2021 8:20 pmThe center bolt should be long enough to go into the threaded hole in the drive shaft.
Re: Help needed
I just rechecked the drive gear assembly. The outer bolts protrude slightly through the hubcap, but with nothing to screw into anyway on the hub. The centre bolt doesn't protrude at all and therefore couldn't be screwed into the hole in the end of the drive shaft ( the bolt diameter is also smaller than that hole ).
- Has liked: 790 times
Re: Help needed
Hi Andy
I have the 2017 version of a late Tiger 1 so it might be different than yours. On mine, the sprocket hubcap was meant to be a push fit (or maybe bonded) into the sprocket. Have a look here where I made a little modification so that the hubcap could be bolted to the sprocket.
viewtopic.php?f=6&t=6937&start=285
As I said your version could be different than mine.
Re: Help needed
Thanks for reply Vince. I suspect that you are right in that the hubcap needs to be glued into the sprocket as do the cone bolts.Vince Cutajar wrote: ↑Fri Feb 19, 2021 4:53 pmHi Andy
Re: Help needed
Just be aware that if you glue it to the sprocket than it could be difficult to remove it in the future.
