Bump stops.
Has liked: 1485 times
Been liked: 1695 times
You have a PM :D
Dale jordan
Been liked: 514 times
Post by Dale jordan »
Adrian I posted the parts yesterday . Remember when you guys make the bump stops you should use 25mm x 10 or 12mm . alloy rectangler bar . the template is only 6mm thick .. Dale
Lionel Champ
Been liked: 1 time
Post by Lionel Champ »
Hi Dale,
Did you copy your design from a real Tiger or is it your own? I am building the late Tiger which comes with L shaped bump stops. They certainly work, but I don't know how authentic they are.
Lionel
Roland Mann
Been liked: 19 times
Post by Roland Mann »
Hi Lionel,
the real bump stop has not been changed during the time Tigers where built. Not easy to make a 1/6 model. When I started the job, I did not know how diffficult it will be at the end. However, the final result is satifaction for my ambitions.
If you like to go this route, the drawing is attached. Let me know if resolution is too low. I can send the original PDF of my drawing to your email.
Best regards Roland
Der Weg ist das Ziel.
Lionel Champ
Been liked: 1 time
Thank you Roland
Fantastic piece of work. The photo is fine and clear. I don't have any access to a milling machine so I think that I will struggle to make them as good as yours. I understand that they are hard to see when fitted so I'm sure my limited skills will come up with something?
All the best
Lionel
Roland
Beautiful piece of work.
Has liked: 161 times
Been liked: 831 times
Roland, Fantastic work. If you guys want to see some really fantastic work check out Rolands detailed 88mm gun for the Tiger 1, absolutely stunning.
