Centurion 23
- Has liked: 1038 times
Re: Centurion 23
Bob hi. It's a thermal blanket to insulate the barrel in order to minimise barrel droop. (Pause for comments....). When a barrel gets hot from firing, there can be differential cooling effects from wind and rain, which can reduce the accuracy at long ranges. I think the UK was the first to identify the effect but thermal jackets are pretty well universal these days. They were a pain because you had to remove the ones nearest the muzzle in order to remove the fume extractor for cleaning. They did the job though.
Great model Luc. Well done, although the .50 is a bit optimistic. I don't recall the UK using them as commander's MG although they were certainly common on US tanks. Great gun, still is.
All the best.
All the best.
- Luc De Weirdt
- Been liked: 16 times
Re: Centurion 23
Today I placed the smoke unit in the Centurion.
If you want to see a little video of that test just click here.
- Been liked: 1 time
- Luc De Weirdt
Re: Centurion 23
Thank you steven.
Today the tank made his second test drive in the garden.
The video: please click here.
Thank you for watchin'.
- Has liked: 605 times
- Been liked: 147 times
- Luc De Weirdt
Re: Centurion 23
Thank you Kevin,
Yesterday I tested the climbing ability of the tank.
Time for a new video: Please click here.
- Been liked: 2 times
Re: Centurion 23
Hi Luc,
That looks great
I wasn't going to get the smoke module, but it does add a little extra.
I like your mantlet cover, did you use any sort of pattern or just measure and stitch?
Also the aerials move nicely, were the bases scratch built?
Robin
That looks great
Robin
- Luc De Weirdt
Re: Centurion 23
Hi Robin,
Thank you.
The smoke module is something great to have in your tank. I use it in combination with the Smoker Fan Control Unit from Adrian Harris.
The mantlet cover is made out of one piece of fabric. I just had to make the holes for the main gun and MG. On top I glued some extra pieces of fabric and the airbrush did the rest.
As I was building the centurion I wanted to give the three aerials their natural appearance.
They had to move gently in the wind and they also had to wave on the rhythm of the moving tank.
So I could not use the usual steel antennas but I found the solution in nylon antennas.
I made the bases for these antennas with my lathe.
Thank you.
- Luc De Weirdt
Re: Centurion 23
- Luc De Weirdt
Re: Centurion 23
Westfront Customs from Holland changed my commander's figure into a great looking animatronic: Please click here to see the animatronic in working condition.
- Been liked: 3 times
Re: Centurion 23
Nice! Here's another movie of luc's animatronic
http://www.youtube.com/watch?v=Qo7jhSaP ... e=youtu.be
It has 5 functions. Head - Neck - 2x arms - Waist.
If anybody is interested in one feel free to send me a PM.
- Luc De Weirdt
Re: Centurion 23
- Has liked: 793 times
- Been liked: 8 times
Re: Centurion 23
Luc, that's a very good looking Centurion, you should be very happy the way it has finished up. The commander is excellent by the way !
- Luc De Weirdt
Re: Centurion 23
Thank you Martin.
Here are some new pics of Rosie:
Thanks for watchin'
Thanks for watchin'
- Been liked: 68 times
Re: Centurion 23
Hello Luc.
Now I like that Centurion.
Really looks the part well done you must be very pleased.
Cheers Paul.
Cheers Paul.
01524 720977
01524 720977
