Hi Adrian, I had a go tonight on the exhaust tubes and muffler, you were right the 180 degree turn was a bit fiddley, because I wanted to keep to metal tube, I used brass because that's what I had and it is a slide fit into the copper, I found a steel spring that fitted inside, and heated the tube over a flame until it bent to shape,
regards
Jeff
