Hi Damon
Yep that's the picture and I put a link above your post .
Click the link and its the picture you have posted.
But thanks for putting it up as a picture and as I said you can see a washer between the nut and the arm.
Regards Derek
The SdKfz 7 begins
- Has liked: 219 times
- Been liked: 197 times
- Been liked: 438 times
- Has liked: 103 times
- Been liked: 92 times
Re: The SdKfz 7 begins
I've checked a couple of things with Kian regarding page 16 of the manual.
1) Part CG1244C is shown held by an M8 Nut. If vehicle is going to be run it requires an M8 washer also.
2) Part CG1244A has 2 small threaded holes in its side. If vehicle is going to be run then it requires M4 Grub screws in these holes to help keep shafts in place.
Something I also discovered after assembling and fitting the Front Spring Assy, was that you need to pay close attention to the exact way the leaves are aligned. I had CG1231 the other way round to that shown on the diagram, with the end with the slight upward curve the same side as the tubular shaped end of CG1230. This caused the spring to foul on the M3 X 20 button screw holding CG0229 at the other end.
- Has liked: 70 times
- Been liked: 302 times
Maybe this should be put in the AT thread on the SdKfz 7 so everyone might know?Andy Walker wrote: ↑Wed Feb 26, 2025 4:34 pmI've checked a couple of things with Kian regarding page 16 of the manual.
- Been liked: 1715 times
Hello 7 builders, i used a Nyloc nut on this part, seems to work well and you dont need to tighten too much and allows plenty of movement in the arm, regards simon.
- Has liked: 22 times
- Been liked: 61 times
[/quote]
What is the "AT thread on the SdKfz 7" please.
[/quote]
- Has liked: 841 times
- Been liked: 75 times
What is the "AT thread on the SdKfz 7" please.Colin Stevens wrote: ↑Fri Mar 07, 2025 6:25 pmMaybe this should be put in the AT thread on the SdKfz 7 so everyone might know?
[/quote]
Colin,
The AT thread is where they announced the 2024 kit and build out is found here:
viewtopic.php?t=10198
Damon
Mid spring assembly finished. Where necessary, parts were sanded, and then all parts were cleaned, etch primed and undercoated. Each individual leaf spring was given a coating of white lithium grease before final assembly.
