once upon a time there was a Hetzer..
Forum for discussion relating to the Hetzer (Jagdpanzer 38)
Timo Haehnle
Has liked: 56 times
Been liked: 74 times
Re: once upon a time there was a Hetzer..
Post by Timo Haehnle »
Thanks for the advice Adrain.
Yes its true, Armortek says in the manual it should be mounted "slack".
Well I changed the way I mount the arms and will test it the next days. I hope it will work. If so, I will post it here :D
Timo Haehnle
Has liked: 56 times
Good news, the Hetzer is growing, and the box of parts is getting more and more empty 8)
I wasn't sure when the best time would be to install the motors, thinking it would be better to attach the sprocet wheels first. Unfortunately, it quickly became apparent that you couldn't achieve the 20 Nm without a gearbox attached, because there is now way to lock the sprocet wheels without a gearbox. So, there was nothing left to do but install the motors. Then it became clear while I was following the manual and did step 1,
I did not realize that the motors should be attached as soon as possible. The reason for this is, you can't reach the four mounting screws for the flange to which the motor and gearbox unit are mounted. The best is indeed to follow the advice in the Manual removed the front panel again (it was only temporarily attached) and then a side panel. A lot of work for eight screws, but there was no other way.
My advice: If you want to build the Hetzer, install the motors as early as possible, even before attaching the side panels.
Oh, and consider whether you want to paint the inside of the tank before you start the first step. As you can see from the photo, it's not always a good idea to do it afterward. You can't see it once the front panel is installed, but it annoys me.
To better understand the space available, I temporarily placed a few components, including the speakers, in the tank:
There isn't THAT much space in the tank, especially since the rear slopes down, so a lot of height is lost.
The smoke generator has also found its place. A little less "wasteful" would have been cool, but that's how it's intended, and that's how it's currently mounted. Maybe I'll change that later.
Next, we moved on to the aiming and traversing mechanism for the cannon, as well as the barrel recoil.
In my previous post I mentioned the collision of the mechanic with the cannon housing. This is how I solved it:
Now it's time to install the new LiFePo battery. Luckily, a standard 24V/25Ah battery fits.
Then it was time to wire up all the components before they found their final place in the tank.
Unfortunately, it looks a bit wild, since the servos are already installed. :P
I'm currently busy installing the components, which will take some time. Only if everything is 100% functional, I will install all insinde the tank. To ensure the switches, speaker controls, and fuses are accessible later, I made a cardboard template to mark the position of the hatches.
The tank commander even came by to test the seat. ;D
Timo
Timo Haehnle
Has liked: 56 times
Now everything found its place inside the Hetzer and I was sorting out the cabling. Everything was working as it should be.
Then I mount everything again in the tank, and the sound was not working any more. The "switch on" beep was sounding but no more sounds could be triggered with the 3 way switch and no more driving sound.
I thought it might be the cables. All out again and check. Everything is where it belongs.
Okay might be that I need to do the programming of the sound module again.
I switched on the tank, (switch on beep sounds) and then I pressed the programming button. The programming beep was there, but when I do the programming like it was stated in the manual it did not recognized the input from the 3 way switch I guess. I simple cannot confirm the starting of the engine sound position.
I changed the cable between receiver and Sound Modul, I changed the channel in the receiver 3 times and even used another 3 way switch on my Graupner MC-20 hott. Nothing helps and I am running out of ideas. I there a way to fully reset the Sound Modul?
Any advice is highly appreciated.
Timo Haehnle
Has liked: 56 times
Luckily I get another sound module from Mark, so the sound trouble is fixed.
Right now the smoker fan is not running at all, so here I have to doublecheck the wires.
If the wires are right, I will try to use a direct channel from the reciever and test if the fan is working at all.
If thouse problems are sorted out, its time to mount the roof, ad the last small parts and the go for the painting
Timo Haehnle
Has liked: 56 times
al long time there was not really any kind of update of the building process here. This was because of personal trouble and the time pressure to finish the Hetzer for his first engagement.
I promise I will fill the gaps in the building documentation, but here a the fist pictures and some small videos from the RC meeting in Röthenbach an der Pegnitz here in Germany. It was a great meeting with a nice team onside. Many thanks to the Modellbaugruppe Röthenbach an der Pegnitz!
Timo Haehnle
Has liked: 56 times
and here the Videos:
Sorry for the video during the night, the quality is not as good as I would like it to be, but it was a special experience in driving the Hetzer.
Has liked: 1480 times
Been liked: 1685 times
Looks like Youtube has pulled a couple of your videos as well :shock:
Timo Haehnle
Has liked: 56 times
Adrian Harris wrote:
Mon May 12, 2025 7:12 am
yes and I was honored with a warning.
Looks like somebody has to train their KI better. Because I am from Germany I know there is no tolerance for a Swastika or SS Runes.
But evon on the injury medal of the commander I removes the Swastika. So 100% legal.
Well then no more videos :(
Chang
Has liked: 16545 times
Been liked: 487 times
Post by Chang »
Hi Timo, Have you submitted appeal to these illogical removals?
Recently I have experienced similar situations , from my 2008 to 2011 yrs videos. Reason is always was the "Hate Speech " policy. Except one of them had I said something that was not hate words. All of others not a single word was said.
viewtopic.php?t=10566
I appeal them all. Two were come back. The rest weren't. So always to appeal it.
Lerh Chang
Timo Haehnle
Has liked: 56 times
Thank you for the tip"
Yes I requested a review of the videos. Lets see if they really review it.
Timo Haehnle
Has liked: 56 times
YouTube did not accept my review. The vidoes are deleted and the warning stands.
I uploaded the videos now to Dailymotion. Hope the work not with AI but with people they can understand what an RC-Tank is.
Klaus Uschkurat
Has liked: 2693 times
Been liked: 11 times
Post by Klaus Uschkurat »
Hallo,
soweit ist es gekommen das Maschinen uns kontrollieren :(
Wir bei uns sagen Deppenhaufen :mrgreen:
