Panzer III build
Has liked: 1470 times
Been liked: 1642 times
Hi Jeff.
That lip certainly seems to be present on both of the Bovington and APG Panzer IIIs for which I have photos.
I do have one set of photos from http://www.worldwar2aces.com/panzer-tank/panzer-iii/ which show an Ausf IIIM without the lip but that's the exception to the rule :wink:
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
Because I need to make and position, the wood trough for the aerial, I had a go and made the aerial and hull mount, it could connected to a servo and raised using a spare channel
regards Jeff
Been liked: 1732 times
another nice detail jeff,i'm saving all these posts,so keep em coming, is the aerial holder made of wood. regards simon.
Totally amazing Jeff! I just can't keep up. :) Outstanding project to watch and follow.
Kindest regards
Jeffrey Goff
Has liked: 20 times
Nearly finished fitting out the side track guards, just the "S" hooks and the brackets for the jack to do, I scratch built the pry-bar in steel, and made the aerial trough, jack block and tool handles from hardwood, I also made the starter handle and Tetra fire extinguisher, to place all the pieces in the correct positions left lots of unwanted holes these have been filed
regards Jeff
Has liked: 151 times
Been liked: 822 times
Jeff, Outstanding details. I love the fire ext even down to the rusted mounting bracket. Your aerial came out fantastic. Really inspirational, even to those of us who don't have a P3. Keep it going.
Jeffrey Goff
Has liked: 20 times
made a start on the brackets for the jack, this is what I made tonight, it needs cleaning up and painting, and I will make the other one tomorrow
regards Jeff
colin fairweather
Been liked: 9 times
Post by colin fairweather »
very nice :D
colin :)
2006 222 SOLD
2009 pzr111 046 SOLD
Jeffrey Goff
Has liked: 20 times
both side track guards fitted out, and front brackets fitted, (thanks Stephen) I would not have seen these from photos;
I am making a start on the rear hull, to make the engine air intakes more to scale I am cutting out the webs and will fit new ones
regards Jeff
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Jeff,
Stunning detail once again. I now see how the aerial is supposed to be on this tank. Why was there a multi-leaf spring in one direction and only a single leaf in the other direction, it seems strange to me?
I've just come back from 2 1/2 weeks in Florida watching the Gatornationals drag racing and spending a week at Daytona, with a passenger ride in a NASCAR, very nice but the weather could have been a little warmer, it seems everyone has suffered a bit this winter. I'm back out to Kansas tomorrow for business, but the down side is that I'm not back until next Sunday so I'll miss out on a bit of Easter.
Allan Richards
Jeffrey Goff
Has liked: 20 times
Hi Allan all this globe trotting is not good for you it severely cuts into hobby time, you should be thinking about a new tank to build, the Comet looks really good with some great details included
regards Jeff
still looking,still impressed, simon .
Jeffrey Goff
Has liked: 20 times
I have been working on the air intakes, first I cut out the existing webs, and replaced with steel ones of a thinner section, it was quicker for me than machining and filing all the angles square, I then made the mesh screen and cover, on the original the edges of the mesh were wrapped around a wire frame, and in turn the whole wired to the cover, a bit fiddly but can be done, I have also included a picture of the new front bracket
regards Jeff
Has liked: 1037 times
Superb Jeff, as ever. I came to the same conclusion about the mesh covers for the intakes ie that a scale mesh isn't available and the only way to get the right pattern was to make it. The square pattern you've modelled is on the Bovington vehicle and it looks good. There is also a diamond pattern, woven in a slightly different way, so for the sake of variety, I'll have a go at that. I seem to spend all day in the workshop with little to show, so I'm constantly amazed at the speed of your very fine builld.
All the best.
Jeffrey Goff
Has liked: 20 times
Hi Stephen, I did think about fitting the mesh so it looked like the diamond pattern, but it would have been difficult to fix the wires neatly to the frame, I had a go at making the chain link mesh, but that was a step to far,
regards Jeff
