Pt 2
Setting up an Armortek model on OpenTX in its basic form is straightforward, he said......There is a lot of help out there. There are guides to setting up aircraft on YouTube and useful material on the OpenTX website but this commercial guide, which is updated with each major software release, is really useful to find your way around the menus and understand the structure of the software:
- Unknown.jpg (12.96 KiB) Viewed 4427 times
https://alofthobbies.com/taranis-plus-user-manual.html
https://www.t9hobbysport.com/taranis-x9 ... ser-manual
What follows isn't an exhaustive guide but just a flavour of what's involved.
There are a couple of things to set up on the radio page, including binding the receiver, then a new model is created. It's best to avoid using the New Model widget, which is intended for model aircraft.
Short press MENU to open the MODEL SELECTION page - long press ENTER on a vacant model slot, CREATE MODEL and EXIT to avoid the widget.
Short press PAGE to select the MODEL SETUP page. Enter a name, scroll down to INTERNAL RF and select XJT 16. Scroll down to CHANNEL RANGE , select CH1-8 (TELEM ON).
SELECT BIND, press ENTER (TX beeps). PRESS the BIND BUTTON on the RX and power up. Flashing RED LED indicates BIND COMPLETE. When power is restored, the GREEN LED indicates Bind successful.
The radio is now talking to the model. Now to set up the model.
INPUTS
Short press MENU to enter the MODEL SETUP pages. Short press PAGE to navigate to the INPUTS page. This page tells the radio which physical entry devices (sticks, pots, sliders, switches) will control which logical function. This is an important concept. Forget channels for a moment, the logical function is what you want the model to do, so for example drive forward and reverse, steer, traverse turret, etc. This is my INPUT page for the usual driving functions and control of sound, searchlight and barrel smoker. Thr, Ail etc are the names given to the four sticks, SG etc are switches, S3 is the Rotary Encoder.
MIXES
Short press MENU again to select the MIXES page. This is where the logical functions are translated into logical channels (up to 32). Channels can be combined, added to each other or subtracted. Channels are what you want the radio to do. So for example, DRIVE and TURN are combined by adding them to each other to give us single stick driving, as ever. Despite its name, this page isn't about mixing in the old analague radio sense. It's better to think in terms of what effect you want each of the physical input controls to do - it's the brains of the whole setup. This is my MIXER page for the Cent.
OUTPUTS
Short press MENU to select the OUTPUTS page. Here the logical channels (what you want the radio to do) are translated into the physical channels on the receiver. The Channels here relate to the physical connections on the receiver. The OUTPUTS also set the physical conditions of the devices being controlled, such as servo limits, reversing, mid points etc. As with the other pages, it's helpful to give each line a name which reflects what it actually does, such as TRAV, SMOKE, LIGHT etc. This is my OUTPUTS page:
For a basic model, that's all you have to do.
To begin exploring some of the power of OpenTX, I also wanted to fire my barrel smoker with the momentary switch which controls the special sounds, so that now when I select Main Armament sound and trigger it, the gun firing sound is played, the barrel smoker fires for as long as the switch is pressed and the laser in the barrel fires. That's much easier than the setup with the Spektrum, which required two switches and a rotary knob selection to be co-ordinated. This sort of advanced functionality is setup using LOGICAL SWITCHES and SPECIAL FUNCTIONS. This is where I struggle as my mind isn't as logical as I'd like to think. It helps to have the simulator in the OpenTX Companion. You can play around with the setup and test it in the sim until it works as you wish.
These LOGICAL SWITCHES create a condition - the condition is TRUE when the rotary encoder is selected to the main armament special sound, which causes the sound channel to output a certain value AND the momentary switch is positive ie the sound is playing. The condition is FALSE when the rotary encoder is set to any other position ie any other sound is selected, OR the momentary switch isn't positive.
This SPECIAL FUNCTION tells the radio to activate the smoke channel to run the barrel smoker and fans for as long as LOGICAL SWITCH above is TRUE (ie as long as the correct sound is played.
The model setup is stored in a file on the TX SD card, in a format which can be read by any OpenTx software. A basic configuration setup might be worth developing and made available to anyone starting out. Doing it from scratch though does help with learning the software.
This is really only scratching the surface of what OpenTX can do. Pioneers like Liam in Australia have pushed it much further and when the Taranis becomes the Armortek default radio, there will be a lot more applications. Owners of the Lee/Grant might find that a lot of the complicated stuff going on with the guns can be made much more flexible and controllable.
