Dale easy eight No 65
Dale jordan
Been liked: 523 times
Re: Dale easy eight No 65
Post by Dale jordan »
Just about ready for casting
Has liked: 162 times
Been liked: 849 times
that looks excellent Dale - nicely done!
Dale jordan
Quick question are the 8mm pins for the suspension pivots stainless steel ? Dale
Dale
I don't think so, I think they are carbon (ie non-stainless) steel. I replaced mine with 316SS to prevent rust.
jwwirds
Has liked: 76 times
Been liked: 26 times
Post by jwwirds »
I’m not sure whether it’s stainless. I exchanged mine for a brass tube. I put a thread in the tubes so I can remove them if necessary.
Building Sherman Easy Eight
Leopard 2A4 ordered
Dale jordan
Really happy with the look of the casting detail on the suspension arms I filled the webbing holes from the back . Dale
Dale jordan
One finished five to go . Dale
Excellent Dale - I agree really nice addition.
Dale jordan
Lower hull painted Olive Drab . Test fitting bogie number one I used loctite 480 for the first time boy its strong I had one tyre on crooked had all types of trouble getting it off . I hat to use a razor knife to get under the rubber , lucky only one to do . Dale
Dale jordan
Dale jordan
One side done . Dale
Dale jordan
one track on . Dale
Dale jordan
Following Daves lead again . I did raise the position of the MG port and over a bit as well . Dale
Dale jordan
Put a lot of work into the side hatch today plus made new lifting hooks to the correct size and repositioned them . . Dale
Dale jordan
A bit of work on the rear vent and gun mount Dale
