I have been playing around with some laser cutting and have managed to get some small spanners cut from 4140 Chromalloy sheet 1.6mm thick. I have tweaked the hex shape a little to get a better grip on the nuts and they are working very nicely, the ring end will break/strip even high tensile bolts before bending (up to M3). Obviously the open end is not as strong as it has no material build up to compensate for the opening, but they are very handy for those hard to get to but firm to turn nuts.
As the cuts are very fine relative to the plate thickness it is hard to get a clean flash free cut, the flash is relative easy to remove but can be time consuming so I am offering the spanner sets (13 off from 2.5mm to 7mm) “as cut” for AU$85 but for those that do not want to remove the flash a finish set is AU$145, plus fees and freight.
Small Spanners
- Been liked: 304 times
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1075 times
Re: Small Spanners
Oh very cool Liam. I'll go for a set. One can never have too many tools.
I'd say I want to be buried with my tools like the Pharaohs of old so that I have something to do in the afterlife....but I'd need a pyramid sized workshop to fit them and all my 100+ model tanks.
I may as well just begin sending you all my money...
I knew this was going to happen once I gave in to 1/6 scale...
- Paul Sparkes
- Has liked: 91 times
- Been liked: 223 times
Re: Small Spanners
Liam,
Laser etch a popular brand name onto them and charge loads more
222 scout car
222 scout car
- Has liked: 258 times
- Been liked: 187 times
- Has liked: 67 times
- Been liked: 284 times
- Paul Sparkes
Re: Small Spanners
Agreed they are superb and very useful.neil graham wrote: ↑Fri Feb 16, 2024 9:38 pmMine arrived yesterday and I can attest to their excellence.
Money well spent!
222 scout car
222 scout car
