The ALL NEW Armortek drive system for tanks
- Has liked: 72 times
- Been liked: 315 times
- Been liked: 50 times
Re: The ALL NEW Armortek drive system for tanks
From my understanding of a sensed brushless motor with the sensors connected to the ESC, as the load on the motor changes so the power supplied to the motor changes to try and maintain a constant speed of the motor. This should make loading the tank back into the transportation vehicle a lot easier as for a given stick position you will have a stable speed.
Some of the ESC for brushless motors can be set to provide what is called "drag brake force " which should slow the vehicle down when the stick is in the centred position. I would hope that the new Armortek drive system has this as it is a useful fail safe position as without it even on level ground it would take some distance for the vehicle to stop due to inertia if there was a communication failure between the transmitter and receiver and the fail safe conditions were activated.
David.
David.
- Gerhard Michel
- Has liked: 3 times
- Been liked: 687 times
Hi guys,
well, with my non-Armortek-Models I have some experience in using spur gear drives (with brushed motors), which are as smooth running as belt drives. This is very useful when moving the model by hand or tow it by another model, but it may be rather dangerous on the ramps, and the model will run down every hillside in an unattractive matter.
Therefore we have ESCs with electromagnetic force brakes built in (good ESCs allow to use this brake even stepless by an own RC channel, but this is not really necessary). Then the model 'crawls' down the hill (or the ramp!) when the stick is in center position, and it is a real pleasure to watch this without any own action! Of course the model remains steerable if necessary.
I'm sure that this option is also possible with brushless motors, when the ESC is suitably constructed.
Another problem of smooth running drives is curving and turning. A tank rolls very smooth when driving straight ahead, but it needs much more power to curve or turn. My models with steel track links use 15 times more current in table turning than in moving straight ahead! With smooth running drives the tank attempts to roll further ahead instead of turning, because instead of turning the model the outer motor pushes the inner motor by its track drive. A worm gear stops this effort, a smooth drive needs support by the ESC. In my ESCs this is realized by a so called flyback diode which shortens the motor in the non-pulse periods. I think that this method can be applied also in ESCs for brushless motors.
Gerhard
Gerhard
- Gerhard Michel
Hi David,David Merritt wrote: ↑Tue Nov 28, 2023 10:22 amFrom my understanding of a sensed brushless motor with the sensors connected to the ESC, as the load on the motor changes so the power supplied to the motor changes to try and maintain a constant speed of the motor. This should make loading the tank back into the transportation vehicle a lot easier as for a given stick position you will have a stable speed.
David.
from the pics shown here I suppose that these are unsensored BL-Motors.
Gerhard
Gerhard
- Has liked: 1121 times
- Been liked: 990 times
Thanks Armortek.
This is a feast for my eyes.
Robert Tanzer
Sweden
Robert Tanzer
Sweden
- Been liked: 3699 times
Gerhard, I am not sure how you can see that from the photographs, but the brushless motors we are using have sensors.Gerhard Michel wrote: ↑Tue Nov 28, 2023 11:08 am......
Kian
For anyone concerned about the control of brushless motors just watch Benjamin’s video on the VESC?
No you won’t need to know how to program to this level but it is an indication of what is possible, and yes from the 15:45minute mark that is full speed forward to full speed reverse to full stop and you can’t even see the motor stop to reverse.
I along with Paul Sparks have been using brushless for some time now and the difference in performance and drivability is remarkable, smooth and controllable. Yes they are faster but no they do not consume more power, they are the correct solution to kit evolution.
I don’t usually comment but this topic has too much unsupported dialogue, and yes I drive an electric car which is the same technology.
Liam
Liam
- Gerhard Michel
Hi Kian,Armortek wrote: ↑Tue Nov 28, 2023 6:56 pmGerhard, I am not sure how you can see that from the photographs, but the brushless motors we are using have sensors.Gerhard Michel wrote: ↑Tue Nov 28, 2023 11:08 am......
Kian
sorry, but I missed to see the seperate wiring for the sensors.
Sensored BLs in combination with suitable ESCs have additional benefits especially for tank models, of course; e.g. when turning or driving downhill. Such a driving concept gains advantage over all previous concepts, I mean, because it comes closest to a mechanical steering superposition gear.
Gerhard
Gerhard
- Jerry Carducci
- Been liked: 1116 times
Of course I recognize the power of a brushless motor motor but I can't help but think of a Le Rhône radial engine when I seen some types
of BL motors run...including some smaller ones I have.
- Has liked: 6 times
- Been liked: 812 times
Any indication on pricing at this stage? Will the current brushed pack still be available as an option?
- Been liked: 1842 times
I do wish that Benjamin would stop grabbing that live rotational device, the future pain can be considerable, trust me I know.
And for all the cleverness of electrickery, unless you have a brake enabled servo drive motor. No power, no brake action!
Don't forget your choc's
Perhaps a dumb question..... but is this available yet?
Yes - shipping started earlier this week and working through the waiting list.
- Has liked: 79 times
- Been liked: 113 times
For which models will the new drive system be available first?
How much will the new system approximately cost?
- Has liked: 4 times
- Been liked: 25 times
Hi,
What is the max continuous current on this setup say in a high stress environment?
