sdkfz 7 Flak build
- Been liked: 1756 times
sdkfz 7 Flak build
Hi all, Winter is here so time to start my next Project, since building the previous sdkfz 7 i still have the enthusiasm for another, i was lucky to acquire this started vehicle, The build level so far is good so decided to carry on with the same version, a late production Flak vehicle, I have the Flak already , a metal Chinese Model Produced in the 2000s , i will post some photo's as i go, regards simon.
- thumbnail_IMG_3858.jpg (78.5 KiB) Viewed 14735 times
- thumbnail_IMG_3857.jpg (78.61 KiB) Viewed 14735 times
- thumbnail_IMG_3847.jpg (104.7 KiB) Viewed 14735 times
- thumbnail_IMG_3846.jpg (106.87 KiB) Viewed 14735 times
- Has liked: 11 times
- Been liked: 119 times
Re: sdkfz 7 Flak build
If that's up to your usual standard that's going to be stunning mate. Look forward to watching the progress on here. Steve.
- Has liked: 155 times
- Been liked: 827 times
- Has liked: 887 times
- Been liked: 81 times
That will be another beauty, looking forward, as always, to your take on this rare machine.
Thanks Forum Members, The vehicle is something different to build, The photo's are of the Flak kit i purchased, at least 10 years ago, has any one seen this kit before, and who made it, regards simon.
- thumbnail_IMG_3871.jpg (77.13 KiB) Viewed 14526 times
- thumbnail_IMG_3870.jpg (108.45 KiB) Viewed 14526 times
Just Making a start to build up a bit of momentum, checked the motors and the inner brass bush, all good, some dismantling needed to replace a few rusty nuts etc. regards simon.
- thumbnail_IMG_3879.jpg (145.21 KiB) Viewed 14412 times
- thumbnail_IMG_3872.jpg (119.75 KiB) Viewed 14412 times
- Has liked: 26 times
Hello Simon,
interesting building. I still have a kit of the flak lying around here. Thanks for the suggestion.
Jan
Jan
I have turned the chassis over and started servicing the suspension and steering, due to the vehicle being left in a damp shed, while i have access to this section i have repainted and weathered the underneath, even though you will never see it, all the best simon.
- P1260580.JPG (170.25 KiB) Viewed 14094 times
- Has liked: 20 times
- Been liked: 737 times
Looking good Simon, I vaguely remember those flak kits - all metal. Perfect match for SDKFZ7. Was this same company that made 1/6 Searchlight?
Following with interest.
Thanks Bob and Jeff, i have been working on the Front Grill, Re-working the center bars, Radiator cap and more pronounced radiator cap neck, plus re fitted the motors and some weathering to the chassis, the hard to reach areas, it's always a bit repetitive in the beginning, but you have to start somewhere., all the best to all you builders in 2024, regards simon.
- thumbnail_IMG_4062.jpg (66.58 KiB) Viewed 9180 times
- thumbnail_IMG_4060.jpg (90.72 KiB) Viewed 9180 times
- thumbnail_IMG_4058.jpg (124.78 KiB) Viewed 9180 times
- Has liked: 99 times
- Been liked: 446 times
Utterly stunning work, Simon! As always!
Looking forward to following this build.
Cheers and happy New Year to you and all my fellow modelers!
RPR
RPR
Thanks Robert for the Encouragement, i have added some extra detail to the Armortek kit Front wheels which are a very nice part in themselves, Grease nipples, Air valves and reshaped the center caps, i also started to get to grips with the instrument panel and bulk head which will be a lot of work, all for now, regards simon.
- thumbnail_IMG_4143.jpg (132.22 KiB) Viewed 6313 times
- thumbnail_IMG_4142.jpg (91.78 KiB) Viewed 6313 times
- thumbnail_IMG_4140.jpg (97.75 KiB) Viewed 6313 times
- thumbnail_IMG_4127.jpg (86.26 KiB) Viewed 6313 times
Hi All, i Have done a little work on the 7, soldered the Dashboard Holding frame in and made a start on the instrument Panel, working out dials and switch positions, regards simon.
- thumbnail_IMG_4174.jpg (97.44 KiB) Viewed 5810 times
- thumbnail_IMG_4173.jpg (99.3 KiB) Viewed 5810 times
- thumbnail_IMG_4172.jpg (99.54 KiB) Viewed 5810 times
Hi all, I am still working on the dash panel, reproducing the dials has been tricky, getting some clean accurate detail, I have made a few to practise, regards Simon.
