36 road wheels, 1152 parts, not to mention individual ops/wheel.
I am only learning by the way and currently rationalising the KT parts for storage as I would like to complete Chieftain first.
However I am finding something call "mission creep" with both projects, i.e put hull together( dry fit), armopax, eBay, KT tracks, etc.
I do like the annodized track though, where in the UK can get this stuff?
Cheers all
Charles
KT 40
- Charles A Stewart
- Has liked: 511 times
- Been liked: 932 times
KT 40
- Been liked: 1842 times
Re: KT 40
I've got Chieftain stashed all round the house at the moment.
I Really need to sort that out. Starting two models would drive me round further the twist.
How far are you with the Chieftain.
- Charles A Stewart
Re: KT 40
Thanks John, for your reply.
I will post on the Chieftain forum. Chieftain things here, I believe we will get into trouble.
However, cracked the photo thingy!
Anyway what I now have is a very expensive (themed?) storage box until it is time for the build.
I will as the evenings draw in, clean, prime etc. sub assemblies, but not yet.
Cheers Charles
Cheers Charles
- Charles A Stewart
Re: KT 40
Hi all,
La'al progress due to VCG, many will suffer this, its also holding up Chieftain too, sorry "VERY COLD GARAGE".
If this is old news then fair play and apologies. I recently had a circular from "AVIATION BOOK CENTRE", Supertiger, reprint £55 & Jagdtiger @£35.
Cheers all
Charles
Cheers all
Charles
- Charles A Stewart
Re: KT 40
Good evening all.
Confession time: I bought a milling machine in January, it was a second(bought & rejected), however repaired & a lot cheaper than a new one. It will doo for what I am doing. Where am I going with this you wonder?
Presently rationalizing the workshop/garage, so I have taken the opportunity to have a go at detailing the bottom of the KT (I fear John Clarke's mirror) and get some practice with the milling machine. Once done It will be moved out of the way so I can move back onto the Chieftain.
On a recent visit to the Tank Museum I was able to obtain some photos of the various belly plates/access hatches, see below
This is the water drain. Has anyone a picture of what was attached via the six bolt holes?
Take care all.
Charles
Take care all.
Charles
- Charles A Stewart
Re: KT 40
Good evening all.
Been working on the belly plate of the KT, with the help of these two emotionless, though focused characters. Also had a go at simulating welds in milliput. Good thing here is it will be difficult to see when the tank is completed
I did cheat a bit as I found pre cut discs on a well known buy/selling site which save some work.
The rear panel does not fit correctly, AT have supplied me with a replacement. Once I have sorted out the lower hull (get bored with filing) it will be back to the Chieftain.
Take care, have fun.
Charles
PS That spanner does fit M3 bolts.
PPS Jacking pads, if that's right will be fitted when belly plate & lower hull all satisfactory.
Charles
- Charles A Stewart
Re: KT 40
Hi Folks.
Just to say I have now sold No.40.
Charles
Charles
Re: KT 40
Hope KT has gone to a good home, a bargain, should have been snapped up weeks ago.
Since the two cybermen are now out of a job, I've given them a chance on Chieftain. but they'll have to up their game!
- Charles A Stewart
Re: KT 40
Hoy you!
I'm sending the taxi. These guy have enough work to do here my good man
Charles
PS I don't know how long this comedy/drivel could go on
Charles
Re: KT 40
Darn it, those chaps were just starting to get the hang of it, Now I'm left with this guy, useless, aggressive and keeps dropping the sonic screwdriver!
PS well I'm booked up here for a couple of years at this rate.
