Yves sdkfz 9 update
yves mouton
Been liked: 741 times
Re: Yves sdkfz 9 update
Post by yves mouton »
Thanks for the replay Derek.
Best regards Yves
florian rudolf
Has liked: 297 times
Been liked: 645 times
Post by florian rudolf »
Look here
yves mouton
Thanks Florian,
Now i understand it :)
Made some progress on the famo.
Best regards Yves
yves mouton
Hello
I have a question, can you use a actuator ( like steering actuator for the famo )
for a recoil unit for the ( pak 40 ) i wanne use that on my sdkfz 251? If you connect the actuator on the Armortek recoil
module will it work fast for shooting and pull back slowly
Best regards Yves
Has liked: 1486 times
Been liked: 1695 times
Actuators tend to use a motor turning a screw thread, so would never be fast enough to work as a recoil.
yves mouton
Thanks Adrian
Little update, i cut down the fenders
Best regards Yves
yves mouton
Hello,
A little update again,
Workt on some details on the fenders.
Also made a plate to close the famo on the underside.
Best regards Yves
florian rudolf
Hi Yves,
why did you close the underground with this plate?
Florian
yves mouton
Hello Florian,
I like it more with a closed bottom, i did
this also with my 251
Ps: your foto's of your famo build are a great help for me thanks.
I also orderd some U- profiles for the functional window.
best regards Yves
florian rudolf
Hi Yves,
glad to help you. :D
At the 251 it is helpfull to close the bottom.
Reason is dust in the suspension and in my case to protect the electronic parts.
At the Famo the suspension is allready protect with the tubes. :wink:
yves mouton
Hello, Florian
The wing nuts that you use on the window is this M2 or M3?
And were can you find these? I have wing nuts from Armortek but i think they are M3 and that's maybe a little to big?
My profiles for the window arrived yesterday from germany ( Knupfer )
Did you cut the window glass with a dremel?
Something else: It is a little bit strange that there no springs on the idler system of the famo??
I think i will put some springs on it.
Ps: where did you find all the different sides of rivits?
Best regards Yves
florian rudolf
Hi Yves,
well the wing nuts are M1,5.
I have all the rivets, screws and nuts from knupfer.
I milled the disc.
Which deflection system of the Famo do you mean??
yves mouton
Hello Florian,
I cant find wing nuts on the Knupfer webside.
I mean the Idler system ( to change the tracktension ) i think it is safer with a spring on.
They use springs on the idler of the stug 3 also.
Best regards Yves
Has liked: 793 times
yves mouton
Thanks Vince
Best regards Yves
