Yves sdkfz 9 update
- Been liked: 561 times
- Has liked: 288 times
- Been liked: 637 times
Re: Yves sdkfz 9 update
Hi Florian,
I already download a lot of pictures and information of your famo build.
Best regards Yves
Best regards Yves
Hi Yves,
thats good to hear. - I hope it will helb you.
Ich you have any questions, pleas write
Good luck
Florian
Good luck
Florian
[/img]Hello,
I started on the famo.
Re-tap the thread (deburr)
Drill and put m3,2 split pins in the suspension arms.
[img] ttps://i.postimg.cc/x1mRBwXH/20230528-161458.jpg [/img]
Best regards Yves
Best regards Yves
Hello,
A little update on the Famo,
Work this weekend on the tracklinks.
I put Loctite 480 on the sides of the rubber pads.
For the screws i use loctite nr 243 ( blue )
Also put the rivits in the wheels
Al the rivits are done, now i started on the idler wheels.
Best regards Yves
Best regards Yves
Hello,
A little Famo update,
Working on the wheels and sprockets and torsionbars
Suspension bars test fit.
Best regards Yves
Best regards Yves
- Has liked: 118 times
- Been liked: 752 times
Looking excellent - the road wheels look great with a little removal of machine marks. I used big rubber band on my Panther wheels similar to zip ties. Works great! Nice work, will be a beauty.
Good morning Yves,
looks great. Go forward it will be a nice new Famo. I did it the same way
Hi,
Did some little mod on the torsion fix ends.
I cut a flat surface for the grub screws.
Best regards Yves
Best regards Yves
Hello,
Is there sombody who knows what these are for in the famo build??
Best regards Yves
Best regards Yves
- Has liked: 218 times
- Been liked: 176 times
Hi Yves
Those are back plates for the canvas tie downs.
There should be bent wire bits to go with them .
