Quad rebuild
- Has liked: 2279 times
- Been liked: 7191 times
Re: Quad rebuild
Lovely job Jeffrey!
- Has liked: 20 times
- Been liked: 737 times
Re: Quad rebuild
Thanks Phil, now the paint has dried you can see how the spare wheel was held in place
Re: Quad rebuild
Another month has gone by since I did any work to the quad, so this week I looked for some small details to add before I finish putting it together, made and fitted the side lights, a little over size but was restricted by the size of the bulbs, also made the dashboard lamp, I wanted the bulkhead lamp to work and found is easier to make a new one out of brass,
Regards Jeff-
Re: Quad rebuild
Seasons greetings to you all, managed to get a bit done today, lights fitted inside cab, decided to use a small Lipo battery in the inspection bay and a switch on the dash, also made new windshield wipers
Regards Jeff- Robert E Morey
- Has liked: 153 times
- Been liked: 822 times
Re: Quad rebuild
Love the interior shots Looking awesome inside and out -Jeff! Seasons greetings!
Re: Quad rebuild
It has been a few months since I worked on the quad, reorganised the electronic bay, charging made easier, and battery monitoring via rear door, made and fitted steel rear mudguards, also made and fitted the fuel can carriers, just some trim to add
Thinking of selling the quad, full options with futaba tx and charger, any interest pm me
regards Jeff
regards Jeff
Re: Quad rebuild
Bit more work on the quad, made a working tow hook, copied William Gardeniers, it’s a good design and easy to do, the lighting uses 12v bulbs and I wanted a separate battery, (3S lipo) fitted in the front on the fire wall and a manual switch on the dashboard, to make charging easy I hinged the bonnet
regards Jeff-
Re: Quad rebuild
Added the springs and catches for the bonnet, door stays and roof canvas, also made and fitted brass guttering, a bit more trim to add then a tidy up, (windows are filthy) then it should be done, if anyone is interested in the quad, pm me
regards Jeff
regards Jeff
Re: Quad rebuild
Finished the gutters using brass angle riveted on, made the latch plates for the storage bins, and made the rifle racks from steel brass and copper, these will be bolted on, not a fan of glued on white metal, it invariably breaks or drops off
regards Jeff-
Re: Quad rebuild
I am bringing the quad build to a close, gun racks painted and bolted on, rear view mirrors and rear reflector added, driver in position, I will be putting this on the for sale section
regards Jeff
regards Jeff
Re: Quad rebuild
She looks good Jeff.
