Churchill AVRE
Forum for discussions relating to the Churchill
Chris Hall
Has liked: 535 times
Been liked: 686 times
Re: Churchill AVRE
Post by Chris Hall »
I don’t know if WW2 fascines were different from WW1 ones, but the WW1 ones were made up of smaller bundles of brushwood then bound into one big bundle with chains, which were tightened by two tanks pulling in opposite directions ……
Yours looks more like a long length of bound sticks coiled up. Is that right for WW2 ?
David Skeldon
Has liked: 33 times
Been liked: 312 times
Re: Churchill AVRE
Post by David Skeldon »
There were many different types as later in the war I think they just used what ever they had locally. I am just experimenting at the moment with size me to see how it looks.
Gary Richardson
Has liked: 787 times
Been liked: 1878 times
Re: Churchill AVRE
Post by Gary Richardson »
Hi David
Your AVRE is looking great. I too have been researching fascines as I want my 8 ton derrick to be functional and raise a fascine onto another AVRE. My problem is the weight of the fascine, which is quite substantial. An average full size fascine was 12' wide and 8' high so at scale that is 24" x 16" or 609mm x 406mm.
I worked out the circumference as 50" or 1274mm and just the outside layer of twigs I tried weighed over 4kg.
Have you made any further progress with your fascine and if you have, could I ask how much it weighs.
Gary
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Hi,
Too much to do at the moment so no further progress with the fascine ,but the one in my photo is 26 inches wide with a diameter of 14 inches and weighs 12.5 kg.
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
First test of pulling a Gutted Carrier
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Testing my Petard, was not happy with spring power so now using CO2, need to make a better dummy Petard, but test firing getting about 12 meters. Filmed in slow motion on my iPad.
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Re: Churchill AVRE
Post by Kevin Hunter »
I hope I’m not the only one who glanced at your post and saw the water feature (?) as a substantial ball bearing hurtling across your garden to take out the fence? !! :D
Andy Cameron
Been liked: 58 times
Re: Churchill AVRE
Post by Andy Cameron »
I had to take a few glances and then play as was also impressed with the large metal cannon ball initially
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Now working on my second AVRE.
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Just found this on YouTube . Just shows how slow the Petard fires.
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Second AVRE taking shape
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Been raining a lot so decided to make some deep wading trunks.
Gary Richardson
Re: Churchill AVRE
Hi David
I like your latest addition of the wading trunks, what material did you use and what fastenings are you using to hold them in place?
Gary
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Hi,
They are 1mm steel, they will be bolted on semi permanent as doing it as if they were fitted originally would be too fragile and make access into the engine bay awkward. But it will be possible to use original fixings so if at some time I wish to have them fall off like the real ones I can do so.
David Skeldon
Has liked: 33 times
Re: Churchill AVRE
Basic setup of the deep wading equipment.
