Hello
Has anyone done muzzle flash in their MG34?
How have you done it?
Or can you buy such an MG34?
Greetings
Robert T
MG34 muzzle flash
- Has liked: 1118 times
- Been liked: 990 times
- Has liked: 790 times
Re: MG34 muzzle flash
Do you mean the cupola mounted MG34?
Steve Winstone used to do the front part of the barrel only.
- Has liked: 297 times
- Been liked: 645 times
In Austria I know someone build muzzle flash for gattling in Heli. Unfortunatly hav'nt found his page yet.
This is not a MG34 but I think a good solution for muzzle flash.
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1110 times
It's probably not what you're looking for but I drilled a tiny (really tiny) hole through the barrel of a 1/16 MG 34 and wired in a micro
led buried in the flash hider. This was for a top mounted MG on a StuG III. The hair like wires are easy to conceal.
It's under the control of an MFC system.
MG simulation
If a led can fit in one that tiny a 1/6 scale MG would be a piece of pie...
MG simulation
- Gerhard Michel
- Been liked: 678 times
Just a hint: the Beier sound module allowes synchronizing MG flash LED and sound.
Another solution is a real MG, firing 6 mm blank cartridges out of a rotating cylinder, even with general permission; I mean.
https://www.jetarrows.com/_en/model-can ... gun-mcg05/
Gerhard
Gerhard
- Ed Groenenberg
- Has liked: 96 times
- Been liked: 639 times
Now THAT is a cool addition to any tank....
Ed
Ed
- Gerhard Michel
Well, a friend of mine has this real MG in his Helicopter. Very impressive!
Gerhard
Gerhard
