Modified casing fillets
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Heres some shots of the casing fillets i have modified to look more like the original.
The modified fillet placed over the original fillet.
The original fillet installed.
The modified fillet installed (much better :D )
Better get back to the decorating before the wife gets home :roll:
Tim Bowman
Been liked: 177 times
Post by Tim Bowman »
Thanks Steve!
Those look very nice. Perfect timing. I'll be milling the rear armor plate's top edge today to accommodate the adjusted, lowered rear deck. Once that's done I can focus on the lower hull and those two casing fillets just happen to be sitting on my work bench at the moment. :) Will you be adding the recessed bolt holes on them too?
Nice flush screw on the hull floor too. :D
Keep up the great work!
Steve Norris
Has liked: 8 times
Hi Tim,
Yes , i hope to resess the holes. I will fit studs into the hull with nuts to retain the fillets. The fillets are attached using the same holes as the gear case and there is just enough thread available to fit the studs and use the supplied M3 x 20 bolts to mount the gear cases from the other side.
After doing the first fillet using a Dragon Tiger for reference i had a look in Roland Manns gallery and found that he has produced scale drawings and machined new fillets. Looking at his and mine i think i have got them fairly close
Roland Mann
Been liked: 19 times
Post by Roland Mann »
Hi steve, indeed you got it right. The bolts I used are one piece M3x30 going through the gears housing and still long enough to reach the fillets.
However this lenghts includes the 2 mm thickness addition I have done to the inside.
Excellent work you have done. Keep going this way.
Roland
Der Weg ist das Ziel.
Steve Norris
Has liked: 8 times
Thanks Roland
nice detail,good info,good photos,keep the tiger forum buzzing!
simon manning.
Steve Norris
Has liked: 8 times
Finished fillet
Mike Kasputis
Been liked: 54 times
Post by Mike Kasputis »
Nice catch on the fillet, I missed that (Now I might have to fix this on mine :x ).
