I have a Jeti DS16 Transmitter and receivers left over from my helicopter flying days.
A very nice quality transmitter.
Before I sell it and move on to something else is anyone successfully using this with the later Armortek electronics?
Thanks.
JETI DUPLEX DS16 Transmitter - Compatibility?
- Has liked: 457 times
- Been liked: 930 times
2022 Panther G #15
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1116 times
Re: JETI DUPLEX DS16 Transmitter - Compatibly?
If you have an Armortek system you could do a simple bench test to determine if you could control the motors to begin with.
Those Jeti systems as I recall are quite costly.
Re: JETI DUPLEX DS16 Transmitter - Compatibility?
Thanks Jerry, unfortunately at the moment I do not have any Armortek systems to test it with.
Maybe I will have to just wait for now until I can get my hands on a motion pack for the Tank.
2022 Panther G #15
A quick update on this.
My Jeti DS16 has now been setup and works with the later Armortek modules.
Motor control needs to have a couple of mixes put in to get the motors running in the right direction.
The three way switch for the sound is very easy as well.
As this time telemetry and failsafe have not been set up and fine tuning will obviously be required once the electronics are in the tank.
2022 Panther G #15
