Sherman Easy 8 track problem
- Has liked: 5 times
- Been liked: 12 times
Hi folks, I have been fighting a problem with my right hand track climbing over the outboard drive sprocket. I have played with the tension and a couple of the return rollers trying to find the reason . When it does this the tension becomes so tight I have broken 1 track link and bent a pin. I have to break open the track to get it off the sprocket. I have added a link but could not get the proper tension so removed it. I know the Sherman likes a tight track but it sure looks way too tight to me. Not sure where else to look for the resolve. Any suggestions would be welcome.
- Been liked: 525 times
Re: Sherman Easy 8 track problem
Could be an alignment problem riding the track up over the sprocket ... Dale
- Chang
- Has liked: 16586 times
- Been liked: 487 times
My twice experiences :
Go checking the taper lock bushing. If broken, could cause the final drive axle-sprocket wobbling , then mis-aligned the track.
Good luck!
Good luck!
- Has liked: 74 times
- Been liked: 14 times
When it is only the outside sprocket it climbs on to, it could be the sprocket is bend.
I have taken off the drive sprocket and the taper bushing is fine, the sprocket looks good, not bent or wobbly. The track still come over the outside sprocket in the forward direction. Not right away but after a few minutes of running. I noticed I have a track link that seems to be very stiff on its pin and starting to think it may have have something to do with it. slow speed seems ok but if I increase the speed to full it will come off
- Has liked: 17 times
- Been liked: 26 times
I had this and it was a tiny stone had gotten into one of the track link holes.
- Has liked: 166 times
- Been liked: 849 times
The stiff link could be the sole problem. I would take those links out and file them so they are not stiff when assembled. I had to file many links a tad so they were smooth running. Sometimes the track pin hole is not perfectly centered or perpendicular to the link and the links will bind when assembled. This will definitely cause a jump. Also there is very little clearance of the sprocket teeth to the holes in the links - the sprocket must be carefully aligned to the rest of the track, wheels.
- Been liked: 2 times
Bob, did your issue get resolved. I’m starting on the assembly of the links this month and was curious what you found to be the problem? Thanks, Jerry
Jerry, that's a better question for the original poster - John (did he get his issues resolved).
Greetings from one Coloradoan to another. I live in WA now but consider CO my home.
My tracks are smooth as silk, but took some time to assemble. The track pin hole varies in location a small bit and can cause binding links. Also the links are from a 2 part mold so have some flash in the location shown below (at red arrows). I filed a little material from these locations on sticking links and this eliminated the binding.
Thankyou for the update. Did you prime and paint your tracks after they were assembled?
I treated my tracks with aluminium black before assembling. I assembled with a small amount of copper grease on each pin. I then painted the rust and mud effects on the assembled tracks.
Some have assembled and then etched but this would result in the copper grease washing out and I thought that is a good long term easement for the tracks.
I've put a few km's on the Sherman now and it's still going strong. I've had one track come off from a stone getting caught in the front sprocket when turning whilst on gravel. I won't do that again.
Sorry gents, Yes I got the issue resolved by pulling some stiff pins and reworking a couple of tight holes for a much better alignment for the pin into the link. I did have to replace 1 sprocket that got chewed a little too much. A new issue is stripping out the socket on the 3mm track screws. Gone through 4 of the wrenches.
Jerry I primed the individual inks before assemblyJerryBarnes wrote: ↑Wed Oct 26, 2022 8:21 pmThankyou for the update. Did you prime and paint your tracks after they were assembled?
