(I'm biased).
David built an excellent model and I have not had to do anything to it. The odd touch up, added a couple of drivers periscopes and got the coax MG to flash.
I love to admire it and just drive around the garden where it's busily looking good, which it does magnificently.
Just one thing annoys me. The turret transverse not being able to spin the turret as many times as I wish. (Almost like a bog standard Heng Long 1/16 plaggy tank)
I suppose like all Armortek turrets, it has the same problem, until Chieftain arrived and it's 8 wired slip ring.
I don't want helicopter, but I don't want to have to keep remembering where the turret should be, without twisting the turret wiring into some sort of rope shaped mess, worse, damaging the turret wiring.
So I thought 12 wire slip ring, what could go wrong! First there's 15 wires in the turret
Every wire is a separate circuit. Bugger
So a 16 wire slip ring is on its way from the USA. Three actually, Centurion, Chieftain and spare.
It's also an opportunity to fit quick release plugs allowing turret removal. I hate resting the turret on the hull where the wiring is restraining any movement.
This is also a dry run for the Chieftain. I want multiple channels in the turret including recoil, flash, stabilization and lighting, this all controlled by a second receiver in the turret (Taranis x9d) so this is a chance to see what the reliability will be like
Brought a couple of new batteries to put into the Cent. The old ones have a few years on them, still good, charging them every three months.
They'll come in handy for Chieftain setup and sizing.
So when the slip ring arrives I'll slip a new set of batteries in too.
