Hi Kian,
Hope I am not too late, still Monday !,
I would like 2.5 x 12. 200
x 16. 200
x 32. 300
Tim forbes
Special offer on M2.5 Hex heads
- Has liked: 4 times
- Been liked: 1 time
- Been liked: 3630 times
Re: Special offer on M2.5 Hex heads
Thanks for all your orders.
The production order has gone in and we expect delivery of the fasteners in the next 4 weeks or so. Will contact you closer to the date.
- Has liked: 380 times
- Been liked: 261 times
It appears to me that the Armortek roadwheels uses the same bolt/nut dimensions on the inner and outer bolt circles. As far as i know the outer bolt/nuts are of a larger dimension than the inner circles on the original late Tiger 1. May i be so bold to ask whay this isn't corrected during manufacturing? One more tool change during cnc operation, and we're good to go
The holes are drilled as clearance for M2.5. If you choose, you can go all the way down to M1.6 nuts on the inner ring.Søren Sandvold wrote: ↑Wed Aug 18, 2021 8:18 amIt appears to me that the Armortek roadwheels uses the same bolt/nut dimensions on the inner and outer bolt circles. As far as i know the outer bolt/nuts are of a larger dimension than the inner circles on the original late Tiger 1. May i be so bold to ask whay this isn't corrected during manufacturing? One more tool change during cnc operation, and we're good to go![]()
We generally try not to provide anything below M2.5 as the parts become very small and hard to assemble.
- Jerry Carducci
- Has liked: 3 times
- Been liked: 1103 times
Experience tells me it's best not to use M 1,6 nuts on the same surface on which you've just enjoyed a sesame seed roll...
J
J
We have been asked a few times in the last week about M2.5 hex heads - so thought it was worth bumping this information up.
We still have limited stock of these fasteners, so if you are interested then contact us.
Note that these fasteners will shear if over tightened.
M2.5 x 12 HEX HEAD - Price (excluding VAT and shipping) - £0.12 each
M2.5 x 16 HEX HEAD - Price (excluding VAT and shipping) - £0.15 each
M2.5 x 32 HEX HEAD - Price (excluding VAT and shipping) - £0.20 each - Note - only the last 10mm will be threaded.
Minimum order quantity is 200 pieces of any one type.
Shipping will be by normal mail to keep the costs down - or if you have another order in the pipeline we can include the fasteners with that order.
Available whilst stocks last.
