Churchill No. 13
Forum for discussions relating to the Churchill
Markus Beer
Been liked: 55 times
Churchill No. 13
Post by Markus Beer »
Good evening dear Armortek community
I received my churchil no. 13 last week and I am delighted with the quality of the kit.
Of course I had to start assembling it immediately and have already painted the first parts with my desired colour (RAL 6031).
Markus
Charles A Stewart
Has liked: 510 times
Been liked: 928 times
Re: Churchill No. 13
Post by Charles A Stewart »
Hi Markus.
Nice to see such prompt action, good luck with your endeavours. I did notice that you have the ramps ready to load Churchill: Good planning :-D
Cheers Charles
Shayne Sutton
Has liked: 7 times
Been liked: 15 times
Post by Shayne Sutton »
I have received number 9 in Australia and I am currently building the turret along with a rotary firer for the gun using blanks with a recoil generated by the shot, I am also going to improve the detail on my tank and will order so accessories from Armorpax, I changed the gun mount by machining .5mm of the inside of the mounting blocks and installing a spacer on each side so the pivot bolts for the gun elevation can be done up tight, the gun is now fiction free.
Markus Beer
Hello Charles
Thank you very much for the congratulations.
The ramps I need for a long time for my other models such as my badger
best regards
Markus
Stephen Grace
Post by Stephen Grace »
It's hi from no.17 here in the UK, not massive progress here but just been down a bit of a rabbit hole regarding colouration of track links...
GlenStenhouse
Has liked: 17 times
Been liked: 26 times
Post by GlenStenhouse »
Stephen Grace wrote:
Sun Jul 17, 2022 2:08 am
Birchwood Aluminium Black is a good base to start with. Get it from a local gunsmith / shop. This chemically blackens them. Then it's a bit of light detail spray here and there with rust effects. Don't go too heavy as you're building a newish in use version, not a sat in a museum and surface rusted for 70-years version.
Markus Beer
Hello together
It goes on slowly but steadily.
The rollers are mounted on the carrier, now comes the mounting of the roller carriers to the hull.
Markus
Markus Beer
Hello together
I have progressed with the construction of the Churchill.
The drive motors run very well, the turret turning and the raising/lowering of the cannon also works.
Next week I will do the first test runs.
Best regards Markus
Has liked: 161 times
Been liked: 830 times
That's a lot of green! Looking great!
Markus Beer
hello together
so, now my Churchill is almost finished on the jack. the test runs "jacked up" work very well, the chain noise is very metallic. Now only the test drive in the terrain is missing, then the "green monster" can be built ready.
best regards
Markus
Markus Beer
hello thogether
today was the day: my "green monster" completed the first test drives in the open air. I am very happy with the performance but still need to change the settings on the controller. As a size comparison I have photographed the Churchill with my badger 1/7.
best regards
Markus
