Panther G (July 1944 version)
Been liked: 3712 times
This thread will feature photographs of the production parts of the 2022 Panther G (July 1944 version) as we progress over the coming months.
We are now well on our way with the Panther G production and by mid to late June we should be in a position to start assembly of the lower hull.
Suspension bars are all completed:
So are the drive cases:
Hull sides have only just started, so they will be running for a couple of weeks more. Shown below are the left hand hull sides.
and the torsion bar pivots - they have undergone a re-design:
Finally we have the second bump stop. Only just started production of these so they will run for a little while. Again this is a re-designed part.
Plus, you may have seen the video of the suspension arms being made. These are currently in production and with 16 suspensions arms per tank, they will be running for a while.
Jae-seung Roe
Has liked: 316 times
Been liked: 134 times
Re: Panther G (July 1944 version)
Post by Jae-seung Roe »
Thanks for updating the Panther G(July 1944 version :) ) news! So great to see production pictures and also glad to hear that production is well on its way! also Iove to see some completed Solidworks images(rendering images) of 2022 Panther G soon! :D :D
Bump stops for the new Panther G. The bump stop in position 1 still needs a laser cut flange added, but otherwise parts are compete.
And shown mounted on the Panther G left hand hull side.
Turning the Panther G hubcaps on one of our turning centres.
Steve Norris
Has liked: 8 times
Been liked: 701 times
Post by Steve Norris »
Hi Kian.
Great video to watch, it’s always interesting watching these multi axis machines at work.
I noted it took about 2 minutes per hub cap so that multiplied by 16 hub caps is approximately 30 minutes machine time, multiply that by a production run of about 50 Panthers and that works out at 25 hrs machining or just over 3 x 8 hr days.
That’s a lot of machining for what is just a small part of the whole tank and gives a indication of where the cost of these kits is.
Keep the videos coming.
Thanks Steve, always nice to receive some feedback.
Here is another video - this time of the Glacis plate of the Panther G being machined on a 5 AX machine.
Jae-seung Roe
Hi Kian,
Thanks for uploading production videos of 2022 Panther G. As Steve mentioned, I could see the superb level of attention to detail and also great to see some redesigned parts of 2022 Panther G. Watching CNC machine working reminds me when I did my degree show making 1:5 scale car design mock-up using 3-axis CNC back in 2005 :D. Back in that time the assistant manager who was operating the machine so struggled to set a starting point of machine so sometimes the tools were spinning in the middle of nowhere while the cutting oil was being sprayed... :o
Look forward to more production news of Panther G.
Has liked: 749 times
Been liked: 360 times
Post by Christoffer Ahlfors »
These look like dry cuts? How are such speeds possible without flooding? :o
Christoffer Ahlfors wrote:
Tue Jun 14, 2022 8:50 pm
We only ran without coolant for filming - otherwise the camera lens gets covered and you would not be able to see anything.
Yes, that's what I mean. It looks like full speed? If I go anywhere close to optimal feed/speed according to the workshop handbook on my home machine, things start to smoke and the cutter breaks.
Samples of the cold pressed steel roadwheels arrived this week.
Very happy with how they look - just a couple of small tweaks needed on the dimensions and then they should be good to go. They definitely look the part.
A_IMG_2828 (640 x 480).JPG (256.39 KiB) Viewed 6447 times
A_IMG_2829 (640 x 480).JPG (218.61 KiB) Viewed 6447 times
A_IMG_2830 (640 x 480).JPG (202.73 KiB) Viewed 6447 times
David Brady
Has liked: 216 times
Been liked: 840 times
Post by David Brady »
They look really good, nice improvement
nikolas george
Has liked: 52 times
Been liked: 13 times
Post by nikolas george »
Tempted ... sooo tempted :D
Chris Hall
Has liked: 536 times
Been liked: 688 times
Post by Chris Hall »
nikolas george wrote:
Wed Jul 13, 2022 10:49 pm
To quote Oscar Wilde: “the only way to conquer temptation is to give in to it” :lol:
Alex Easten
Has liked: 245 times
Been liked: 217 times
Post by Alex Easten »
Chris Hall wrote:
Thu Jul 14, 2022 7:29 am
Going to be honest, I feel the mojo coming back..
Quicquid agas age
