Armorpax's Armortek UC - No.18
Derek Attree
Has liked: 219 times
Been liked: 198 times
Re: Armorpax's Armortek UC - No.18
Post by Derek Attree »
Hi Dave
Happy new year
I was wondering if you ever got around to paintng your unversal carrier? If so any chance of some photos.
I am finally going to start my build in the next monh or so.
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Hi Derek,
Happy New Year to you too.
Nope, its rusting quietly in the workshop at the moment. I also have the Pheasant in basecoat that needs finishing. I have actually done very little model making over the holiday as needed a break more than I had realised :-)
Dave
www.armorpax.net
Hi All,
Spotted a Carrier at the Overlord show today and liked the way the cover had been stowed. Found a gas cape that was the perfect thickness and with a waxy surface was just what I wanted. Its now cut up into sections and I have quickly test fitted. It will have to come off again as need to get this thing painted soon.
Dave
www.armorpax.net
Has liked: 2274 times
Been liked: 7182 times
Very nice detail, do you have anymore photos of that carrier you can share Dave?
Hi Phil,
I only took these 3 and a couple in the front. I'll email them over in a bit.
Dave
www.armorpax.net
Hi All,
Managed to get a coat of primer on most of the Carrier before the heavens opened. Can't have Phil getting all the glory :-)
Dave
www.armorpax.net
Hi All,
Dummy diff housing to go over the ends of the 2 motors. This is not scale as the motors are way bigger dia than the original diff. The idea is it will sit over the gap between the two motors and at least give the impression of a diff.
Dave
www.armorpax.net
Thanks again to Mr Harris whos' guidance has sorted the sound issue.
www.armorpax.net
Hi All,
Enough gaps in the drizzle tonight to finish the priming. Little filler needed under the rifles then I can start base coating.
Dave
www.armorpax.net
Has liked: 146 times
Been liked: 806 times
Amazing amount of detail in this model - just fantastic. Great work Dave!
Hi All,
Motor cover cast and added.
Dave
www.armorpax.net
Hi All,
Base coating well under way.
Dave
www.armorpax.net
Beautiful selection of parts Dave which make for a spectacular highly detailed model, shame about those two motors that ruin the look of the rear, you can't hide them. I won't shout to loud as I may have to go down the same route but only as a last resort.
Hi Phil,
Opposed to the need to remove figures and loads of detail if I had to repair or adjust the brakes the twin motor set was a bit of a no brainer for me. As you can see from the 1:1 and rear view of the model its not much of a trade off :-) Certainly one I can live with. Visually I didn't have the bottom of the diff case with the original system either.
Dave
www.armorpax.net
Hi All,
Gauges Gloss coated and the box refitted. Ready for Stencils.
Dave
www.armorpax.net
