Size of batteries
Heinz Felgemacher
Size of batteries
Post by Heinz Felgemacher »
Hello,
I´m just got my Sd.Kfz. 222 kit including motion pack.I still need to buy the accus.Has anyone a proposol which brand fits the best? What is the maximum size in mm (L x B x H) ?
What is the best way to fill the gaps between the hull edges ?Any suggestions ?
Heinz :(
Si vis pacem para bellum !
Ad Wouterse
Been liked: 2 times
Post by Ad Wouterse »
Hello Heinz,
Congratulations on your SdKfz 222 and welcome to this forum.
The recommended batteries are acid gel batteries type HGL with a capacity of 12 volt 4,5 Ah or 5Ah. Both these capacities have the same dimensions : 90 x 70 x101/107 mm (length x width x height excluding/including the cable connectors). You will need 2 of these batteries to obtain the required 24 volt. There is no special manufacturer, most "dry cell" brands have these in their programme.
You can fill the gaps between the bodyparts with normal carfiller for steel. On my 222 I used epoxy glue (flüssig Stahl) from the inside to add some extra strength. From the outside I used carfiller for a smooth finish.
Good luck.
Ad
Heinz Felgemacher
Batteries
Hello Ad,
thank you for your fast answer.Which brand can you recommand ? I only get starter batteries for bikes. Where can I get them ? :cry:
Heinz
Ad Wouterse
Been liked: 2 times
Hello Heinz,
There is no particular brand that I would recommend, considering that most lead/gel acid batteries are manufactured in China anyway.
When you search for HGL Blei/Gel or Blei/Vlies Batterien you will get quite some hits. Our friend Conrad has the correctly sized type http://www.conrad.de/goto.php?artikel=250775 but is quite expensive. You should be able to find them at around Euro 15,- each.
Ad
