LiFePO4 (LiFe) batteries become more an more interesting for our tanks. They are light weighting, strong and reliable long life batteries and even cheaper than lead acid types over there whole period of life. Another benefit is that they may be charged with much higher currents than lead acid batteries.
Therefore it may be interesting to have a look at the charging device types available. This depends on using a battery management system (BMS) for the battery pack or not. If a BMS is available a simple and inexpensive lead acid charger may be used, but most of BMS types limit also the charging current. If there is no BMS used than a dedicated charger with balancing possibility is absolutely necessary, but a high-current charging may be applied (fully charging within one hour or less). Such a device is more expensive, so the spared BMS is over-equalized when only one battery pack is to be charged. For more models the BMS-free solution is more favorable, if the circumstances allow that (battery monitoring at discharge!).
A high-levelled universal charger for nearly all types of batteries including all types of Lithium cells with balancing is the Junsi iCharger 4010 Duo. I am using it for some years and I have only positive experiences with it. First of all its only handicap: about 700 € are necessary to pay for the charger and its mains device; even 940 € when choosing the all-in-one set. That's a lot of money, indeed, but there are also a lot of benefits you get. Unfortunately I found no description in English; therefore here is only a link to this device in German.
https://zj-hobbyshop.de/shops/16/8/0/la ... r-4010-duo
https://zj-hobbyshop.de/modules/wbsShop ... tion_id=69
The main advantages for LiFe batteries are the ultra high charging current (up to 70 amps
