Pads on side of UC
Has liked: 1475 times
Been liked: 1674 times
Pads on side of UC
This was posted on FB today. Anyone know what the square pads along the side are for ?
Chris Hall
Has liked: 531 times
Been liked: 682 times
Re: Pads on side of UC
Post by Chris Hall »
I’ve got a feeling it was for flotation tanks ..... but were they ever used in action ?
John Wiggins
Has liked: 257 times
Been liked: 147 times
Post by John Wiggins »
Hi Adrian
They were for the retaining rods that supported the deep wading attachments.
All uc’s from Normandy onwards would have them.
The joins were taped and a lot of gooey black bostik was used to seal them. You can still see the residue left on the sides of carriers later in the campaign, that have had their deep wading panels removed.
I have personal experience with a huge tube of black bostik, as a young lad in the 1950’s . I helped myself to a tube from my father’s toolbox, to try to glue a toy metal lorry I’d broken. I was covered in the stuff when my mother came home, a ruined shirt and a pair of short trousers went into the bin and I had a scuffed ear and scrubbed to an inch of my life. :oops:
Thanks John. Looks like I'll need to brush up on my silver soldering skills, unless one of our aftermarket friends can come up with a product ;-)
Adrian
Graham P Hough
Has liked: 26 times
Been liked: 193 times
Post by Graham P Hough »
Where they also used to mount the canvas cover?
John Wiggins
Yes. :D
Steve Stuart
Has liked: 263 times
Been liked: 192 times
Post by Steve Stuart »
Remember that there is an alternative to welding, brazing, or silver soldering. The much simpler and lower temperature process of soldering, one of the Armortek building Gurus told me it is perfectly possible to lead solder steel. You will need to make sure that you have a suitable flux that is going to 'clean' and allow the solder to flow when the joint is made and also a heat source, whether flame or iron that will pump in enough to keep things molten. This is a technique I will be using to make any lower strength joints and to round out any plate abutments.
Have fun! Steve
Graham P Hough
Has liked: 26 times
I agree Steve, I have used soft solder with a 100w iron to fix handles and other small items and where possible at the back of rivets instead of using super glue where it is hidden as in 25pdr limber. Also as you say Steve we need to make sure the surfaces are clean and grease free. Just don't do what I did and reach for the hot soldering iron with out looking and grab it by the bit - ouch!
Has liked: 745 times
Been liked: 359 times
Post by Christoffer Ahlfors »
Graham P Hough wrote:
Thu Jan 07, 2021 10:24 am
Thanks for letting us in on this secret, Graham! I thought I was the only one on the planet having done such a ehm... thing. :oops: I would never have admitted it if you hadn't gone first!
