Martin's Elefant
Martin Hofmann
Has liked: 151 times
Been liked: 2010 times
Re: Martin's Elefant
Post by Martin Hofmann »
Here comes the next update with the first side walls and the welds.
Also the battery tray is mounted for first loud speaker mount.
Regards Martin
Martin Hofmann
It is time for a little update with the first electric components like loud speaker, battery tray, some relais, smoker and batteries - painted to see only a black surface from outside through the gratings.
mounted from the under side
Regards Martin
Chang
Has liked: 16576 times
Been liked: 487 times
Post by Chang »
Hi Martin,
This Elefant is one of the kind. Watching your photos is an enjoyment.
Found in this photo there are two cylinders (circled). What are their purpose ?
In my Elefant, I turn two drive motors & mounts 90° in upright direction. No problem at all (only possible in Elefant). I think this will save more interior space for other usage.
Testing before final locking photo
Just my two cent. Nobody else have done this, yet I don't think it's a bad idea.
Regards,
Lerh Chang
Martin Hofmann
Hi Chang,
thank you for the compliments.
The two cylinders are the new feet of the bridge for the electronic devices above the big batteries.
Regards Martin
Martin Hofmann
Now i come to the driver and radio operator hatches and the scratch built holders - full functional.
Regards Martin
Martin Hofmann
The cover plate is mounted, the barrel travel lock too and the next Zimmerit is done onto the side walls.
Regards Martin
Martin Hofmann
Now it is time to mount the mud guards with the self made hinges and the spring with holders.
Regards Martin
Martin Hofmann
In the meantime i mounted the barrel, the recoil and all the electric components including the 60 Watt amplifier from Benedini.
I moved the servo for making the hight of the barrel above the bearing of the barrel because in the underground was no more place for it.
Regards Martin
Martin Hofmann
Now the mantlet is welded and the side plates are modified like the Bovi Elefant.
All Zimmerit is done - only missing the rain gatter - this will follow soon
Regards Martin
Has liked: 161 times
Been liked: 849 times
Martin, Looking more and more like the real vehicle. Amazing details, keep up good work!
B
Martin Hofmann
Hi Bob,
thanks for the nice words.
Here are the first photos of the modified pistol ports and the welded rain gutter.
Regards Martin
Been liked: 1768 times
Lovely build Martin, attention to detail, great model, regards simon.
Martin Hofmann
Hi Simon,
thank you for your comment. Your 7 is also absolutely outstanding :!: :!:
Here are the first impressions of camo. The field markings and weathering will follow soon.
Regards Martin
This deserves another post Martin, otherwise what's a Forum for, get the weathering right and the tank will look outstanding, i like that camo pattern and the detail, no pressure, excellent, regards simon.
Martin Hofmann
Here comes the first photos with the new field markings from the 653 schwere Panzerjäger-Abteilung
Regards Martin
