Steen's StuG 3 build thread
Steen Vøler
Has liked: 62 times
Been liked: 498 times
Re: Steen's StuG 3 build thread
Post by Steen Vøler »
:D a bit more to share
sanded and polished the casing for the drivesprocket and also made a bit of a casting look on the sprockets themselves. Hard to see, but it will be nice when painted
lower part of the cuppola was also just fittet
cheers
Steen
Steen Vøler
Has liked: 62 times
A question to the suspension
How much shall the end of the suspension arm be in the corresponding opposite hole where the screw goes in from the outside. If the steel rod is pushed all the way in in both ends, it will not be able to reach the hole.
any suggestions/recommentation?
cheers
Steen
yves mouton
Been liked: 563 times
Post by yves mouton »
Hello Steen,
About the suspension bars, i measure that the suspension rods are on each side just past the two grub screws.
I tested this with a dry fit.
best regards Yves
Roy Beukeveld
Has liked: 171 times
Been liked: 118 times
Post by Roy Beukeveld »
Hi Steen,
I would put both end parts in without the torsionbar first, so both ends (CL0205 and CL0222) can reach the optimum position. Then measure the between inner ends dimension and middle out the torsion bar position.
Kind regards,
Roy
Steen Vøler
Has liked: 62 times
Thanks all for the advice
Not much jas happened, beside tons of work and a house sale that just went through :D
Bump stops and sprocket installed
cheers
Steen
Steen Vøler
Has liked: 62 times
Some dry fitting work done today
cheers
Steen
Roy Beukeveld
Nice work Steen, its starting to look more and more like a StuG :)
Kind regards,
Roy
Steen Vøler
Has liked: 62 times
Yes it is 😄
cheers
Steen
Robert Tanzer
Has liked: 960 times
Been liked: 827 times
Post by Robert Tanzer »
Will be a very beautiful Stug next to your Tiger my friend.
Robert
Steen Vøler
Has liked: 62 times
Look forward to the day we can meet again Robert :D
A bit done on the roadwheels
cheers
Steen
Robert Tanzer
Soon my friend soon.
First a vaccination against covid, then load the Tiger in the car and take a trip to your course. :D
Steen Vøler
Has liked: 62 times
Roadwheels waiting for arrival of milliput for welds
You can look forward to visit the panzer drive field. We have now digged trenches also and even built a driving commander platform where we can overlook the entire battle area and drive the tanks from the platform. No more walking behind the tanks for navigation through the battle area
Next is buildings, roads and tree vegetation
cheers
Steen
Steen Vøler
Has liked: 62 times
A bit more work on the stug
cheers
Steen
Steen Vøler
Has liked: 62 times
Some more pics
cheers
Steen
Steen Vøler
Has liked: 62 times
Ready for welding :D
cheers
Steen
