JT in Germany
- Peter Quambusch
- Been liked: 1045 times
Re: JT in Germany
First track test fitted...
- Peter Quambusch
Re: JT in Germany
While waiting for the option packs, continued with some priming, spraying and loosely fitting....
- Peter Quambusch
Re: JT in Germany
Also found some time for size comparison...
JT and JP gun mantlet.Lord, give me strength to change the things I am able to change.... and patience to endure the things I can not change
- Peter Quambusch
Re: JT in Germany
Some more work on the hull...
- Peter Quambusch
Re: JT in Germany
SdKfz 251 with "super heavy Pak"...
- Peter Quambusch
Re: JT in Germany
First roll out....
- Has liked: 1495 times
- Been liked: 1699 times
Re: JT in Germany
Looking good Peter
What's the barrel attachment like ? Can it be easily removed for transportation ?
If not, I might have to drill a hole in the back door of the van
- Peter Quambusch
Re: JT in Germany
Thanks Adrian,Adrian Harris wrote: ↑Sun Sep 27, 2020 6:26 pmLooking good Peter![]()
If not, I might have to drill a hole in the back door of the van![]()
If I were you, I would start drilling.....
- Peter Quambusch
Re: JT in Germany
- Peter Quambusch
Re: JT in Germany
All other owners may simply
unscrew the barrel... ... and store it savely away in the car.
Re: JT in Germany
Phew
- Peter Quambusch
Re: JT in Germany
What amazes me though, despite the weight, you can easyly push / pull the hull with one finger!!
Re: JT in Germany
So I don't need a hole but I will need chains to stop it escaping
- Peter Quambusch
Re: JT in Germany
Lucky youAdrian Harris wrote: ↑Mon Sep 28, 2020 10:10 amSo I don't need a hole but I will need chains to stop it escaping![]()
- Peter Quambusch
Re: JT in Germany
While waiting for the "interior", I continued on the mud guards...
