JT in Germany
Marcus Kwa
Been liked: 39 times
Re: JT in Germany
Post by Marcus Kwa »
Talking of a well equipped workshop: is that a beer tap in the background? :shock:
That explains the lightning speed of the build!
Marcus
mark lawson
Has liked: 2519 times
Been liked: 445 times
Re: JT in Germany
Post by mark lawson »
Peter without sleep this is going to be a very fast build.
Will you build both straight from the box or will you add extra detail to one of the kits.
RAG Militärmodellbau
IG Militärmodellbau
Peter Quambusch
Been liked: 1045 times
Re: JT in Germany
Post by Peter Quambusch »
Hi Marcus,
Yes, that´s my bar in the background. Abused as assembly area... 8)
@ Marc: yes, I will add extras, once the option packs have been installed and the Tank is operational.
Here are some more dry fittings...
Peter Quambusch
Re: JT in Germany
For those interested: the bar...
Peter Quambusch
Re: JT in Germany
Some more trials...
Peter Quambusch
Re: JT in Germany
The boss has arrived....
Peter Quambusch
Re: JT in Germany
Found some time to continue work on the roadwheels and shirts...
Peter Quambusch
Re: JT in Germany
Axles and torsion bars loosely installed, interior sprayed, started work on the weld seams....
Marco Peter
Has liked: 1538 times
Been liked: 798 times
Re: JT in Germany
Post by Marco Peter »
Peter, what material did you use for the weld seams?
'Konan', my Tiger 1 Mid
'Gunther', my Panther G
Peter Quambusch
Re: JT in Germany
I mainly use Acrylic and Milliput.
Peter Quambusch
Re: JT in Germany
Test fitting of road wheels
Peter Quambusch
Re: JT in Germany
Have installed the read wheels on both sides, test fitted left
drive sprocket and started on the left upper hull side...
Peter Quambusch
Re: JT in Germany
Black fingers... :D :D :D
Peter Quambusch
Re: JT in Germany
Weld seams and "rolled steel effect" in the making....
Don Gray
Has liked: 15 times
Been liked: 70 times
Re: JT in Germany
Post by Don Gray »
Looks GREAT!
You are FAST FAST FAST!
