Futaba RX
Philip Allen
Been liked: 10 times
Futaba RX
Post by Philip Allen »
Hi everyone. Any suggestions regarding the location within the hull for fitting the RX in a King Tiger?
Has liked: 2282 times
Been liked: 7196 times
Re: Futaba RX
Hi Philip, anywhere you like as I've never had an issue with the newer tx rx, just keep the rc leads away from all the rest and it will work just fine. 8)
Philip Allen
Re: Futaba RX
Thanks for the quick response :D :D
Has liked: 1040 times
Re: Futaba RX
Phillip
For the best signal coverage, make sure the two small wire antennae are at 90 deg to each other, eg one vertical and one horizontal.
